11-05-2008, 01:54 PM | #1 |
Tallest skinniest tire for 8x15 inch rim
I have a stock height 4x4 and I like the look of tall thin tires. As the post says, I need to know what tall / thin tires are made for a 15 inch rim. I now have 31 inch tires that are , I believe, 10.5 inches wide. I like the height but not the width. Some of the 16 inchers look great to me but the 15 inch selection leaves a little to be desired. Thoughts?
1972 K-10 SWB Cheyenne |
11-05-2008, 03:15 PM | #2 |
Re: Tallest skinniest tire for 8x15 inch rim
33x9.50 dont know if they are 15 or 16
you never know what you can do until you have to undo something you have done! |
11-05-2008, 03:42 PM | #3 |
Built 4 Speed
theres a whole lot of options tire wise.... Super swamper LTBs are designed to be tall and thin..
are you leaving the truck stock? or are you lifting it.. stock i think you will be stuck somewhere around a 32"inch tall by a 9-10.5 (9 is kinda pushing it on a 8 inch rim tho)
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
11-05-2008, 04:12 PM | #4 |
Interco has a
34/9.50-15LT Bias ply 33.80" diameter 9.50"section width 8" tread width GM used to offer 16" wheels as an option for 6 lug half tons. Maybe locate a set of them for more tire options. Not much help from pic but, I like the 255/85-16's on my 86 with no lift. The rims are 6.75 wide. Last edited by Dooley; 11-06-2008 at 07:08 PM. |
11-05-2008, 05:29 PM | #5 |
I should modify my post to say I need to stuff them under stock height (no lift planned. This is an old pic of my truck. Like I said I like the tallness of it but not the width.
11-06-2008, 11:24 AM | #6 |
Modern day Fred Sanford
38/11/15 TSL boggers.I had a set of the 34/9/16 TSL's one time and they worked good.
EDIT,sorry I missed the stock height part. Last edited by 1-tonmudder; 11-06-2008 at 11:25 AM. |
11-06-2008, 12:43 PM | #7 |
my truck is supposed to be stock, but i've got (2) extra springs on the front from what i think i've learned. I'm running 33X10.5 BFG AT's.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
11-09-2008, 09:48 PM | #8 |
Mine is stock in this pic with HD front 1/2ton springs (stock) and 33x10.5x15 BFG AT's on 8x15 Mickey Thompson Classic II's.
The pics with the new bed have a 1.5" add-a-leaf and no weight on the truck... I think they work great and like them... no rubbing.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-10-2008, 12:09 AM | #9 |
This is my 69.. I had the local tire shop order some new steele 16 inch wheels and the tires are a 235/85/16. It has a 4 inch lift.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
11-11-2008, 10:02 PM | #10 |
Hey JRDV can your rims accept dog dish hub caps?? If so where did you buy the rims and , if you don't mind... cost
11-11-2008, 10:09 PM | #11 |
I have some 70's chevy dogdish hubcaps on it right now. I will get you a picture in the next day or two. I think the rims were around $90 a piece, but I will have to dig around to find out. If my local dealer can get them, any dealer should be able too ( I live in the boonies ). I will post some pics later.
john
11-11-2008, 10:56 PM | #12 | |
1972 K-10 SWB Cheyenne Last edited by nyncompute; 11-11-2008 at 10:56 PM. |
11-11-2008, 11:19 PM | #13 |
No problem. I will see what I can find.
john
11-12-2008, 08:35 AM | #14 |
The 34 /9.50 go on a 6 or 7" rim. I think 8" is too wide. With no lift and 8" rims, i would go with a 33 10.50. (they recomend a 7" for this size, but a 8" would do.)
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
11-12-2008, 01:37 PM | #15 |
Here are some quick pictures. The rims don't have a maker on them,and there is no part number.
Stamped on Rim: USA MADE 16X6 DOT........ HEAVY
11-12-2008, 03:12 PM | #16 |
Thanks... looks great! I'll see what I can find out.
11-13-2008, 09:19 AM | #17 |
In 15s I`d say there are BFG M/Ts in 9.50/33.In 16" you can go to BFG M/T 255/85s.I`m not sure if Maxxis still makes Q78 Buckshot Mudders.
Here`s my`92 with 255/85s on newer trucks with stock rims.I can only find them in BFG M/Ts,now:
11-13-2008, 12:52 PM | #18 |
Tim, The Q-78-15 is a 36" tall tire. I think you mean a P-78-15. That is a 33" 10.50 /15. Gateway/Buckshot still makes them. Thats what i run on the race truck. But they are biasply and dont have very good road manners.
11-14-2008, 08:42 AM | #19 |
O K I C.We used to run 9.00-16s.I think they were 34".You "could" run w/no lift w/stock wheels and taking it easy.My unlifted trucks have always had some sort of spring work and would sit up an inch or two,plus not flex as much.
11-14-2008, 10:21 AM | #20 |
So how careful do you think I would have be running a 33" tire at say 10 or so inches of width at bone stock height.
1972 K-10 SWB Cheyenne Last edited by nyncompute; 11-14-2008 at 10:33 AM. |
11-14-2008, 10:35 AM | #21 | |
If you saw issues you could easily install an add-a-leaf or zero rate leaf to assist...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 11-14-2008 at 10:36 AM. |
11-15-2008, 01:09 PM | #22 |
That should be fine.I have 12.50/33s on 8.25" wide wheels mounted on my unlifted`72 K3500.It`s even lower than stock and they clear for normal driving.
11-15-2008, 08:52 PM | #23 |
my buddys dad has 33 12.50 15 on truck rallys the later model ones and he has no rubbing problems at all .
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires 1972 nova plane jane 6 clyinder might sell might keep dont know 2004 chevy s-10 crewcab zr5 sold 1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me 2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went . 1999 k1500 suburban 350 vortec 4l60e leather land yacht . |
