Anyone make thier own trac bars?
Any ideas, got mine dropped 5 in the rear thought maybe i could cut the bar in half and make some sort of adjustment make up for the drop.
It's Better With Nitro
Re: Anyone make thier own trac bars?
I did...since I'm going with a sheetmetal Ford 9-inch rearend housing, the back of the housing extends quite a bit further than a factory-style housing. This required me to move the panhard/track bar and mounts further back, and I fabricated an elongated J-bar-type of panhard bar with a threaded rod end (poly bushed) that mounted to the back of the passenger side trailing arm. The J-bar design was used so itwould pass under the back of the housing and to accommodate the extreme rear drop. I used chassis tabs to fabricate my mounts to the frame and trailing arm. I hadn't welded in the gusset on the back of the trailing arm when my wife snapped the photo, but it should give you an idea of what I did. I hope this helps.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 11-13-2008 at 08:24 PM. |
thanks vin63, where did you get the poly threaded ends from?
Its Deja Vu time again
I suppose it just depends on where you look. Being from the Offroad world I have a tendacy to well look at those places.
http://bluetorchfab.com/store/index.php?cPath=87 http://www.rodendsupply.com/ http://www.currieenterprises.com/ces...nnyjoints.aspx < --- talks about different joints Im sure there are tons more. I just did a quick look on Google. Of course there are different types of rod ends. Johnny Joints, cartidge joints, Heim joints, poly, rubber. Just depends on what your poison is I guess. ![]() Last edited by kizer; 11-13-2008 at 04:19 PM. |
Mine were left over stuff from past projects that I cobbled together. You can get them from most of the race and street rod component retailers, such as Speedway Motors, Art Morrison, Applied Racing Technology (A.R.T.), etc. Look/ask for the polyurethane-bushed rod ends. Or, you can buy a panhard bar (new or used) and modify it - these usually come with the ends and bushings.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 11-13-2008 at 04:19 PM. |
Thanks guys , forgot to mention i am cheap, 40$ per rod end vs. 59$ for whole trac bar from cpp, i think i got my answer.
Your Cheap, heck I got my entire truck for $400 and I might of landed a 350 for $150.
Pays to be thrifty and shop. ![]() |
Made mine from solid 3/4" round stock then made the ends and made it solid for now no bushings then made a quickie mnt for trailing arm to get me buy till now. This was so I could drive it back home and now it sets with nothing holding rearend center because it won't be moving for a while. Once I get the drop done I will make new mounts and make the bar straighter or I might fab some kind of watts link.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 11-13-2008 at 07:56 PM. |
Hollister, CA.
![]() Join Date: Sep 2006
If you want some precision...you could always go with a Watts....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
![]() Join Date: Oct 2006
Watts the hell is going on ? LOL John that is some crazy work !! Nice!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
KOFFIN DRAGGER
I have a trac bar kit in the R&D stages, I will post it and add it to my site once its ready for production.
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
my burb is lowered 5" in the rear and just bent mine for now and it works fine
