Old 11-13-2008, 11:29 PM   #1
dooce
Double Hump Crossmember
Been thinking about edoing the exhaust on my truck soon, and while I'm at it I figured I could replace the trans xmember with a double hump version. What are the cons when using a double hump xmember with a lowered truck with headers? The only xmember I could find on ebay was this one, says for a 4x4, this will still fit my truck right? Thanks, DOOCE
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 11-13-2008, 11:47 PM   #2
og350
og350's Avatar
Re: Double Hump Crossmember
yes that is for a 4x4 it is made for a 203 or 205 t case. it will hang down a few inches from your frame but i dont think that far.
og350 is offline   Reply With Quote
Old 11-13-2008, 11:54 PM   #3
454HO
I don't think that one will work for you. Here is a pic of mine.
You can see below on my 3/5 lowered truck, the 3" exhaust pipes are pretty low to the ground. I'm looking at 3/4 length headers and a custom built crossmember to raise them up a few inches.
- Greg
454HO is offline   Reply With Quote
Old 11-14-2008, 01:06 PM   #4
dooce
Is that the same xmember I posted? I dont know why your headers hang down that low, mine are nice and tight to the cab and should clear that xmember setup just fine
Old 11-14-2008, 02:21 PM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
that one you have posted is for mounting a transfer case, not the trans.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-14-2008, 03:21 PM   #6
454HO
My headers are Hedman Elite long tubes for a '73-'87 big block 2WD truck. The picture above is a little deceiving because of the camera angle. The collectors line up exactly with the large 'humps' in the crossmember. I have about 1/2" clearance from the top of the exhaust pipe to the crossmember. But that also means the bottom of the exhaust pipe is about 2-1/2" or so below the frame rail.
- Greg
Old 11-14-2008, 06:36 PM   #7
Damien
Damien's Avatar
The 4wd cross member is not going to work in a 2wd. The transfer case mount hangs down about 6"-8" below the mounting pad on the transmission case. You would need to have a large spacer for it to work.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 11-15-2008, 05:04 AM   #8
Pyrotechnic
Pyrotechnic's Avatar
I have Hedman long tubes and a double hump crossmember. It looks like Hedman made these specifically for this crossmember. It fits well and looks great, but I run stock ride height and intend to keep it that way. For the stock height, it's perfect. For a lowered truck, long tubes are going to hang too low no matter what you do.
As mentioned above, I would look into 3/4 length Chevelle headers and a custom made crossmember. That is the only way you will get the exhaust tucked up into the frame.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-16-2008, 12:20 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
If you already have the headers, just build one to work. It doesn't take much, and you will know that it fits.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
