Old 11-09-2008, 11:09 PM   #126
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: Thelonerifes 72 stepper
Originally Posted by thelonerife View Post
I got a couple more things blasted. One hood hinge and a 1968 plate.
Nice... I just got a '67 Arizona plate for my stepper. Too cool.
Keep up the good work.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-10-2008, 02:13 PM   #127
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Wow very nice.... Keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-10-2008, 02:31 PM   #128
thelonerife
thelonerife's Avatar
thanks guys!
thelonerife is offline   Reply With Quote
Old 11-15-2008, 11:26 PM   #129
thelonerife
I got one hood hinge painted. I took a pic of the other hinge to show the before and after. Looks pretty good I think.
Old 11-15-2008, 11:32 PM   #130
thelonerife
I got the bottom of the drivers door painted and the inside roof lip, also the white on the front fender.
Old 11-17-2008, 05:30 AM   #131
tdave00
Restoring a 68 SWB
tdave00's Avatar
Looks like progress to me. Keep it up.
tdave00 is offline   Reply With Quote
Old 11-28-2008, 07:43 PM   #132
thelonerife
I took the factory ac stuff off and mounted the new ac compressor and brackets.
v
Old 11-28-2008, 07:46 PM   #133
thelonerife
Old 11-28-2008, 08:08 PM   #134
nuke1
nuke1's Avatar
So Shiney!!!! did you end up going with a vintage air setup?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-28-2008, 10:07 PM   #135
thelonerife
So far I just have the compressor and brackets. i will be getting vintage air or old air to finish it up.I'm getting prices now. My wife said'' you bought that truck because the air worked now your taking it out'' and rolls her eyes. But I want to upgade it now and try it out and if it works I'll do my other truck too.
Old 12-01-2008, 11:19 PM   #136
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Sounds like me, I buy them because they run, then tear them apart lol.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 12-13-2008, 12:19 PM   #137
thelonerife
Well I priced everything else I need for the ac/heat stuff from vintage air and it came to about 950.00. Then I see on ebay a vendor selling the complete kit for 1000 with free shipping so ordered that. So I have a backup compressor now. i just have to wait a few weeks for it all to show up.
Old 12-13-2008, 12:51 PM   #138
5150
C10 Club Tennessee
5150's Avatar
cool Chuck, you can wait about 4 months or so before you'll need it
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 12-13-2008, 01:52 PM   #139
thelonerife
Yeah I know I'm early for the heat but hopefully by then I'll be up and runing. I still have to dynamat the cab too. Ordering that shortly. I'm going to get your lights out this week.
Old 12-14-2008, 05:23 PM   #140
tdave00
Restoring a 68 SWB
tdave00's Avatar
Looking good Chuck.
Old 12-14-2008, 10:09 PM   #141
thelonerife
Thanks Trai. I cleaned up a little bit of that side of the motor area. Got rid of the vaccuum lines and wiring for the old factory air stuff. Changed the vac. port that was behind the carb. put some new vac. lines on. Temporarily fit the blockoff on the firewall. I'll pull it off and trim the clearance needed for the lines and drill a hole for the drain. I'm not going to weld up any of the holes on the firewall as this is just going to be a daily driver not a show truck. I'll post pics. later.
Old 12-14-2008, 10:16 PM   #142
thelonerife
Still have more to do like plug wires, heat shields etc.
Old 12-15-2008, 09:53 AM   #143
tdave00
Restoring a 68 SWB
tdave00's Avatar
BTW...why are you going with the vintage air setup? Is it just more efficient, better technology? Just wondering.
Old 12-15-2008, 02:11 PM   #144
thelonerife
yes and yes. it is more efficient and the newer technology should be easier on the motor. I have the original setup on my other truck and as it does work and blow cold but it is plauged by the problems of an old system. One, the compressors that you get that are rebuilt will work fine but will start to leak oil out from around the clutch area eventually. This is my second compressor since having the truck. And since it still on 12 it runs about 300.00 a pop for getting it up and going again. two,I would rather put that money towards a system that is proven to be more efficient and since the compressor is smaller, less of a strain on the motor at kickin of the clutch. Also parts that are new for the original system are very expensive. The system that was on the stepside did work but wasn't cold enough. I was told by the po that they had to have it recharged every other year. It was converted to 134 btw. There is an option to swap the compressors only but you still have to install some new parts to make it work. I opted to do it totally vintage air to get away from the old stuff altogether.
Old 12-16-2008, 09:29 AM   #145
tdave00
Restoring a 68 SWB
tdave00's Avatar
Gotcha. Just wondering why someone would go with Vintage Air when they had a working setup. Makes alot of sense.
Old 12-16-2008, 01:53 PM   #146
thelonerife
I have been thinking of doing it on my green truck for some time now since that compressor is throwing oil out. I figured since this one needed a recharge and the truck is apart and not in a have to drive case I would let it be my prototype project. If this works as well as everybody says I'll do the green truck.I've gotta have air either way.
Old 12-21-2008, 12:02 AM   #147
thelonerife
I got the Dynamat in the cab. Well part of it. I went up behind the gas tank and by doing that I ran out of it. I will have to get some more. I also want to do my doors so I should have gotten two boxes to begin with. I put he gas tank back in. Ran a tap through all my holes for the tank,seat, and seat belts. I also cleaned my seat belts and they are drying. I'll wait to see how they look. I may have to do them again. I drilled the holes for the trim screw/studs for the rear of the cab/divider molding.
Old 12-22-2008, 11:17 PM   #148
thelonerife
Got two of my wheels in. 17x8 w/4.5 bs.
Old 12-23-2008, 02:07 PM   #149
BACKYARD88
BACKYARD88's Avatar
Sweet wheels! I love that seat too.
-Mike Owen-
Old 12-25-2008, 10:16 PM   #150
thelonerife
Thanks. The seats grown on me and I decided to go with a retro style truck. The seat is sooo dated its pathetic. but now I like it and I even have a sample from sms fabrics for the new plaid. When I decide to redo it that is..
