454 MAKES IT ROAR
Side marker bulbs?
Can anyone tell if the small bulbs in the side marker/blinkers lights on the front fenders and on the bed should be dual filament or single. I thought they would need to be dual, as when the lights are on at night as running lights the second filament would be needed to blink brighter for turn signal use.
Also the bulbs and fittings in my side markers are the push in type the same used in the instrument panel. ![]() Hope i've described this properly. Thanks
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Re: Side marker bulbs?
I think they are just a 194 single element bulb.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB 1967 Custom Short Fleet - 327/4spd |
454 MAKES IT ROAR
Thanks 71stub, are your bulbs the same type as mine? the reason I ask is that the parts stores only seem to stock the metal cap twist in type for side markers.
Old member
Single element but the fronts blink and the rear don't when turn signal is on. NAPA has them and Oriley's, Advance Auto.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
454 MAKES IT ROAR
Also they don't flash on Hazard.
Old member
Take the back ones loose and see if the grounds are good. I have the 71 model deluxe and my back side markers have never flashed.
My rears have never flashed either.
#8 | |
454 MAKES IT ROAR
Thanks guys I'll stop pulling my hair out over this and consider them working as they should be....unless others say different...then i'll start pulling. ![]()
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 11-18-2008 at 11:18 AM. |
Old member
This is with the light swich off and blinker on. Front flashing rear's aren't. Hope this helps.
With light switch on and blinker on. Front blinking and rear's aren't. The parking lamp is on though.
The only rear side marker lights I've seen flash had been rewired to flash. I am 99.9% sure they didn't flash from the factory.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
![]() Join Date: Aug 2008
They do not flash from the factory. My Dad had a 72 lwb Custom Deluxe new and uncle had a 72 Cheyenne new (brother has it now). Neither truck rear side lights blinked.
its all about the +6 inches
This is correct, the rear side markers never flashed from the factory... not even required to by todays DOT standards.
The front, some of them flashed, some did not. Your 4 ways not flashing... try swapping your two flashers around, one for the other. They are the same part number unit, so if swapping them fixes it, you know what you have to do. And finally, for the original question, the above is 100% correct, single, not double. When the parking lights are on, and the side markers flash, it isn't brighter than running lights, it turns on and off. 194 bulbs are the correct number, in american cars they have been the norm since the late 60's in the inst pannel, and are still used today, but not as frequent as back then. Last edited by Longhorn Man; 11-18-2008 at 05:32 PM. |
454 MAKES IT ROAR
Thanks you guys for all your help...Andy4639 thanks for taking the time to post those pics. It's always nice to find out you haven't got a prob when you thought you did...that's the easiest fix of all
Old member
That's why we are here because we all want to help each other no matter where we live.
