Old 11-17-2008, 01:11 PM   #1
DJ72CHEVY
DJ72CHEVY's Avatar
Frame ?
My frame is in pretty good shape. If there is minimal or normal rust between the cab supports, or crossmembers and the frame, is there any need to remove them and use bolts to put them back on? And, are the original rivits better (stronger) than the bolts?
DJ72CHEVY is offline   Reply With Quote
Old 11-17-2008, 03:09 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Frame ?
I wouldnt pull any of the riveted parts apart unless you have to. As for the strength of them pull a couple apart and you will have pretty good respect for those rivets.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 11-17-2008, 03:42 PM   #3
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Re: Frame ?
The only thing I know that is stronger than rivets is welding.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 11-17-2008, 06:25 PM   #4
DJ72CHEVY
DJ72CHEVY's Avatar
Re: Frame ?
Thanks, I will leave them alone.
Old 11-17-2008, 08:49 PM   #5
chas350
Re: Frame ?
Hey DJ, What gives the rivet strength is the tight fit achieved from the swage/peening when it is installed. These are tough to remove. I grind one side off flush and then drive them out with a stout drift and BFH. You will notice a 3/8" bolt fits loosley, do not use them! Even grade 8.
I personally don't trust this, because if bolt to part fit isn't tight, it will eventually loosen and slot the frame/part holes resulting in failure. So what I have done is drill out the frame and part (crossmember,mount, etc) with a 7/16" drill being carefull to not enlarge it with a sloppy drill job. Then pick up some grade 8 fine thread 7/16" bolts, nuts and washers and you will be all set. Just make sure the nuts and washers are grade 8 also, and torque them to 70lbs.
If your really worried about it you can go up to 1/2"
This is plenty strong enough to trust IMO.
chas
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 11-18-2008, 12:42 PM   #6
DJ72CHEVY
DJ72CHEVY's Avatar
Re: Frame ?
Thanks Chas,
The frame is in good shape, I will leave it alone, unless I decide to shorten it.
Old 11-18-2008, 04:40 PM   #7
14U2NV
Re: Frame ?
OK, so the PO of my blazer went the 3/8 route and I had considered going to the 7/16th bolt. I still was leary about that. If I square everything up good and watch the heat, do you guys think it might be better to just weld up the frame?
14U2NV is offline   Reply With Quote
Old 11-18-2008, 08:19 PM   #8
chas350
Re: Frame ?
DJ, dont let that rust go!
NV
I have heard that welding frames can lead to cracks.
What are we considering to weld? cab mount, cross member, spring hanger,etc? Its hard to help with out more info.
chas
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 11-18-2008, 08:55 PM   #9
14U2NV
Re: Frame ?
chas350
I would need to weld all the crossmembers. I would also box the frame where I could. When I had the body off the frame, I felt like there was WAYYYYY to much flex.
Chad
Old 11-18-2008, 10:57 PM   #10
chas350
Re: Frame ?
Hey NV
They are known for a lot of flex. I learned to drive in a 71 LWB Step. My father warned me about placing my hands on the front bed panel when I rode around the farm in the back (harvesting potatos, hay, etc) There was so much flex that your fingers could get pinched between the cab and bed and it did happen to me. Im sure you have noticed they are pretty close together on these trucks.
Anyway all that flex can cause welds to the frame to fatigue and crack. Im sure this would take a while and some rough use. Not sure what you plan to use it for......good luck
chas
quote by LEEVON
70 K20 long fleet
98 G3500 work van
