Re: Project "cheapskate 65"
A Blazer gas tank would probably work if you want the stock route? If not, RCI cells are cheap, and not bad for the price.
If you can find it cheaper, I can fix it! |
RCI's are great, but watch out w/ the welds. They don't have much overlap so are kinda weak. Had the whole back underside around where the sump is crack. Summit paid to have it welded up thankfully. Also local welding guy we took it to said he had seen a bunch of them, and also look out for cracks around the mounts. Just a heads up. Although since its been welded up, haven't had a single issue for 4 years of driving.
