Old 11-18-2008, 11:52 PM   #1
bird7263
Urban Chop Shop
bird7263's Avatar
Help?! 66 Throttle Linkage to 4bbl carb. Need ideas!!
I have included a few pis. I have a 66 with the stock style gas pedal. As you can see I have a straight rod going to the carb. With two springs for safety. The thing is its a little stiff. I am looking for ideas on how to mount up a clean way to have throttle springs. I have seen the high dollar Jegs and Summit mounting brackets.. I am just too cheap. This is rat rod and I want to keep it simple and clean. I have a Edelbrock Air gap intake carter AFB as you can see. Any of you fellas do anything different or have any better ideas? I am not a fan of the el cheapo chrome throttle spring bracket i have on the manifold. Help guys. I want to see how you have done yours. I love to get new ideas.
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods
1965 Chevy 1/2T Longbox, soon to be a slammed shop truck
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266
Semper Fi Marines
bird7263 is offline   Reply With Quote
Old 11-20-2008, 11:59 AM   #2
MikeN
MikeN's Avatar
Re: Help?! 66 Throttle Linkage to 4bbl carb. Need ideas!!
Moroso bracket and return springs, 67 Camaro 396 throttle rod (which is adjustable for length). Neither was particularly expensive.
MikeN is offline   Reply With Quote
Old 11-20-2008, 12:17 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I'm not sure if this will help, or not, but are you able to shorten the throttle rod a little to allow the throttle bracket to clock/tilt forward a few degrees? This might help a little with pedal leverage.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-20-2008, 01:49 PM   #4
502tripower
502tripower's Avatar
Looks to me like your upper spring is in the wrong location. Can you move it to the small hole below. That is where it is spose to be. Also remove the lower spring all together and find a longer spring for the upper. Ideally what it is spose to have is a two springs one inside the other. This acts as a safety.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-20-2008, 10:43 PM   #5
mnky30
mnky30's Avatar
this is what i did on mine i used a hollow rod and some heim joints cut to size and treaded the in side of the rod and works great.
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 11-21-2008, 10:02 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Doesn't get more ghetto RatRod than this...I didn't have a mount for my spring, so what I did, if you look closely....I drilled a tiny hole thru the side of the protruding brass pipe plug, and clipped the spring there. Light weight spring, stock rod type linkage, on an Edelbrock carb.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-22-2008, 01:19 AM   #7
Captainfab
60-66 Nut
Looking at your pics bird7263, I see that the thermostat housing you are using has the little tab on it with the hole......that's where the OEM hooked the throttle spring for a few years. And I agree that you should run a double spring like 502tripower mentioned
