#26 | |
![]() Join Date: Jul 2007
Re: Ever wonder what that fiberglass front end saved you weight wise?
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? |
#27 |
Hey does anyone have any pictures of a 73-87 tilt nose setup finished? looking for how well they fit to the doors etc..
Also, does anyone have the tilt setup that tilts down then slides back to the cowl? Thanks, Jon |
#28 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The USBody pieces are made long on the ends so you can sand the finish to the best gap.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#29 |
yeah I am familiar with that after helping with my friends car.
My main concern is the fit to the contour of the doors as well as how everyone is securing the rear lower portion of the fenders/wheelwells to stop them from vibrating and getting stress cracks |
#30 |
The lower section screws to the firewall, it lines up just like the original fender.
#31 |
One day...
I have had mine for a while i like it a lot! makes the ngine very easy to work on!
#32 |
Hey all I picked up a sweet 1 piece tilt nose this weekend. It has a real trick set of hinges that extend forward about 18" so I can keep the fenders 1 piece.
Not sure of the weight of it yet but its def much more durable than most race weight noses. Unfortunately its the newer 83+ nose and I was originally lookin for the older 73-79 nose for the truck. [IMG] ![]() |
#33 |
One day...
Sweet! is it steel or glass? Have any pics of the hinges?
#34 |
I clicked on the pic and it shows 3 picks in total and two of the hinge. But it keeps scroling so I can't get a great look at it.
Any chance you can mention where you got the hings and better pics?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#35 |
Hope he doesn't mind... If so I will delete this..
#36 |
Who would mind? It's my thread, if anyone it would be me
![]() ![]() That looks like some aftermarket front suspension too.. Let's see more pics ![]() Oh, do you know who makes that tilt hinge?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 11-20-2008 at 09:02 PM. |
#37 |
Hey guys, thanks for posting those pics better. I tried a few different ways and figured a slide show would be best.
The pics with the nose mounted to the truck is the truck it was on before I bought it. It was a 2wd k5 blazer pro street truck. The gentleman I bought it from wanted to put a steel nose on it to make it safer for when he drove it on the street with his wife and daughter. As for the hinges I am not sure who makes them yet. He didn't know much about the origin either as they were on the truck when he purchased it last year. Later on down the road I may be designing a newer beefier set of hinges (the grey pieces) because this nose is going on a tube chassis monster truck. Not sure the 1/4 brackets will be up for the punishment. I have an appointment with a guy who builds fiberglass molds this weekend to see how uch it would cost to make me a mold of the nose so I can replace it easily if/when the truck is rolled over ![]() It's a little easier to make a mold from a 1 piece because there are no seams to worry about which takes more labor to conceal I guess. Oh and the front roll pan is actually steel that was nicel molded to the nose to give it a real clean look. |
#38 |
I was directing that at bigoates.
Some people put the pics in a slide show hoping to "hide" the direct links to the pics from others, and generally don't like them being exposed. The suspension looks like a fatman Mustang II
#39 |
I gotcha.. Sorry bout that
#40 |
#41 |
I sold the front end to another member on the board. Last time I drove the truck it weighed 3,120 with me in it, full 16ga fuel cell and full 15lb N20 bottle.i weighed 202lbs at the time.
That is: No inside of the bed No front bumper No hood Inner fenders cut up some CM back half and cage Glide Alum LS with Super Vic intake and N20 plate Summit racing seats Factory doors Factory glass and regulators Mustang 2 spindles Wilwood brakes on all 4 corners 9" rear
#42 |
mini truck racer
I don't know how tough it would be on the full size . but I'm about to take on Lexan swap in the wing and side windows and the factory tracks that still roll up and down.
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
