Old 11-21-2008, 12:14 AM   #1
jmedero
jmedero's Avatar
yet one more question about Z'ed frames
When I do my Z must I tunnel the trany? What about my 2 piece drive shaft? My truck is a LWB and still trying to figure out if I will cut it down to a SWB or go LWB. Just a picture of what I am working with.
jmedero is offline   Reply With Quote
Old 11-21-2008, 12:34 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: yet one more question about Z'ed frames
If you are talking about a front Z, then it depends on how much of a Z you do
If you have X inches between your trans & the bottom of your cab & you Z that X or more then you are gonna have to cut your floor
A 2 piece drive shaft will mean you dont have to do as tall a tunnel, as the drive shaft doesnt move up & down between the trans & the carrier bearing
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-21-2008, 12:45 AM   #3
FnLow69
FnLow69's Avatar
most likely you will have to raise it....
FnLow69 is offline   Reply With Quote
Old 11-21-2008, 12:53 AM   #4
mr48chev
mr48chev's Avatar
Ok, are you going to Z it on just one end or both ends?
Or you just going to shorten the frame to be able to use a short box? In this case I think we need more info to be able to make viable suggestions.
If you are just going to over lap the frame rails when you shorten them all you will need to do is shorten the drive shaft, emergency brake cable and brake line.
Old 11-21-2008, 12:05 PM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Fuel line & wires too
For the wires you can just loop them & zip tie them
Sinister
Killer
Old 11-21-2008, 07:31 PM   #6
jmedero
jmedero's Avatar
I am going to cut the frame 12' behind the cab. it is a 3 speed but that will be changed to a th350 most likley. What do you mean lap the frame? I plan on cutting it in a L shape kind of cut then weld them together with plates. Is that what you mean?
Old 11-21-2008, 09:31 PM   #7
mycool72
mycool72's Avatar
If you are going to take 12 out from behind the cab are you going to run a four link? Most ppl cut in front of the crossmember to retain the factory two link....if you are going to take length outta the back, you might as well z the back
mycool72 is offline   Reply With Quote
Old 11-21-2008, 10:01 PM   #8
jmedero
jmedero's Avatar
i really have not messured back there yet. The bed is still on and I am working my way back. Got some body work on the front, doors, rockers.... well all over. I plan on doing the frame and susp in Jan and Feb. What is the norm? Before the xmember or after? Is the factory 2 link ok for bag set ups?
Old 11-22-2008, 01:03 AM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Most people cut the frame under the cab between the trailing arm X-member & the front X-member, then relocate the rear cab mounts back into the correct location
And yes, the 2 link is just fine for bags
Sinister
Killer
Old 11-23-2008, 01:41 PM   #10
mycool72
mycool72's Avatar
X2
Old 11-23-2008, 04:25 PM   #11
leftcoast66
leftcoast66's Avatar
Its gonna be a pain though to get it to lay out w/ anything short of a full custom back half w/ the stock trailing arms though. But yes I agree their all good to use if you plan on that.
leftcoast66 is offline   Reply With Quote
Old 11-23-2008, 05:09 PM   #12
XXL
Seņor Member
XXL's Avatar
Unless he's moved it, fuel is behind the seat.
XXL is offline   Reply With Quote
Old 11-23-2008, 11:21 PM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I disagree
You can Z one & lay out just fine
Sinister
Killer
Old 11-23-2008, 11:48 PM   #14
jmedero
jmedero's Avatar
well the plan is to Z @3 then drop spind... I have a front clip from a 82 that I will do ctl arms and brakes from. On the back not sure what to do yet, I guess I will have to figure that out huh...
Old 11-24-2008, 02:17 AM   #15
leftcoast66
I disagree
Interesting. Never seen it done w/ success. Learn something new everyday.
Old 12-04-2008, 04:44 PM   #16
badblu97
Double 6's
badblu97's Avatar
my 82 is Zed 3" and drop spindles, obviously did not get the drop member(wish I could have), and I am aware that the susp in the rear is different, but a parallel 4 link from KP and over the axle bags and its draggin frame...
badblu97 is offline   Reply With Quote
Old 12-04-2008, 10:56 PM   #17
Twisted Minis
Twisted Minis's Avatar
I Z'd a truck, and modified the crossmember to drop the motor back down. You have to run stock manifolds or ram horns in order to clear the frame though. Most headers don't fit when the frame gets raised around the motor.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 12-04-2008, 11:09 PM   #18
scotts62
One day...
scotts62's Avatar
What about the block hugger headers?
Scott
93 crew cab build
Project 62
Old 12-04-2008, 11:44 PM   #19
Twisted Minis
I guess it would depend on the brand. I tried some Hooker block huggers, and it didn't work. That's all I had on hand though. The only thing I found that was tight enough to the block was cast style manifolds. You can get brand new Ram Horns in steel or stainless for under $300 I think, and I actually like the way they look even.
Old 12-05-2008, 01:23 AM   #20
scotts62
One day...
scotts62's Avatar
Ya you would almost have to have them when you do the Z and adjust the frame for it if possible. I was just curious though.
Scott
93 crew cab build
Project 62
