Old 02-23-2003, 12:07 PM   #1
JBARTGMC-10
New To 67-72 Trucks Need Help
HI ALL REALY LIKE BORAD I HAVE LEARNED ALLOT ALLREADY
I HAVE JUST GOT A 70 GMC CUSTOM C-10 LWB WITH ALL OUTER TRIM IN GOOD SHAPE VERY LITTLE RUST JUST SOME REAR CAB CORNERS VERY MINOR NO DENTS JSUT HAVE BRAG ON DEAL OF THE YEAR IT RUNS BUT NEED MOTOR ONLY PAYED 400 BUCKS
FOR THE TRUCK POOR GUY DID NOT KNOW WHAT HE HAD HIS LOSE LOL
MY ??IS THE BADGE ON SIDE SAYS 1500 V-EHIGHT HOW DO I FIND OUT WHAT MOTOR WAS ORIGANL MINE HAS BEEN CHANGED I KNOW I THANK IT IS A 350 IT HAS NEW CARB ,DRIVE SHAVT ,BATTERIE,GOOD DIST.
THANKS TO ALL WHO REPLY
JBARTGMC-10
JBARTGMC-10 is offline   Reply With Quote
Old 02-23-2003, 12:29 PM   #2
Hutch
Hutch's Avatar
Welcome to the board from Texas
First check the option sticker inside the glove box if it is still there.
Second post the VIN number here from the tag inside the driver’s door, and someone will decode it for you.
Probably had a 350 in it originally.
You can also get the numbers off of the block and heads to decode. The numbers are located on the front passenger side on a pad that sticks out to the front of the valve cover. On the back on the block above where the trans bolts on the driver’s side.
Here is a link that will help:
http://www.mortec.com
You can also find some code info here:
http://www.nastyz28.com
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 02-23-2003, 12:33 PM   #3
mtdave2
newly minted old timer
mtdave2's Avatar
one more place if you are lucky. they usualy tucked the actual build sheet in the springs of the seat. usualy behind the seat. work a look. you may get lucky
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 02-23-2003, 12:59 PM   #4
JBARTGMC-10
THE MODEL#CE15934 VIN#CE134SZ72251
4M49KKTURBO HYDRAMATIC
4C60EC A/C
4H05AR REAR AXLE 373 RATIO
THANKS JBARTGMC
Old 02-23-2003, 06:37 PM   #5
Welcome to the board from South Mississippi. I can't help you on the numbers. I only have stuff for GMCs up to 69. It probably is a 350 if it's original though. Like Hutch said, they surest way would be the block and head IDs..
Old 02-24-2003, 12:01 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Wasn't the base engine in a CE truck the 307?
Old 02-24-2003, 02:15 AM   #7
ckhd
ckhd's Avatar
That's what I'm thinking. I'll bet it's 307, unless GMC is different than Chevy on the base engine.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
