Old 11-20-2008, 02:18 PM   #1
clean cut creations
bolts/studs for s/b factory A/C
These are the bolts that I have to install the 7 piece style factory A/C brackets to the cast iron stock exaust manifolds on a small block. Do I have the correct bolts/studs for this application? I can measure and give exact dimensions if needed.
Don't tell me what you're gonna do...SHOW me what you've DONE!!!
Click here for the TRUTH...
clean cut creations is offline   Reply With Quote
Old 11-22-2008, 11:17 AM   #2
clean cut creations
Re: bolts/studs for s/b factory A/C
btt
Old 11-22-2008, 07:53 PM   #3
71 super
71 super's Avatar
Is truck a 4x4? The stud on far right resembles the stud used to hold 4x4 dipstick in place. If not 4x4, the stud is the one located in the water pump for the frant most bracket. The correct studs are the hard pieces to get, the rest is available in the aftermarket. But to answer your question, yes it looks like you have what you need. Harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-23-2008, 11:17 AM   #4
clean cut creations
Thanks Harold! These are all exaust manifold bolts, including the right one, and that SHOULD be for a dipstick retainer. The truck these came from is a 2WD but the previous owner installed drivetrain and several options like factory AC from another truck...POSSIBLY a 4x4? The truck was just missing some important AC brackets and we got that squared away with the help of another post. I just couldn't get info on proper bolts and I didn't want to trust the previous owners building skills! Thanks for the info!!!!
