yes, i do
craigslist score
so the motor that i scored off craigslist for $100 is looking to be a great motor. i took a good look into the cylinders and noticed that the cylinder walls and pistons are clean. the walls even still have the honing marks! i saw that the pistons were 040 flat tops with double valve reliefs. i popped the pan off and saw that the bottom end was clean, and the rod caps had balancing marks on them. everything is nice and tight. the only bad part of the motor is its a 2 bolt main. but i guess we can't have everything right?
Official Site Guitar Shredder
Re: craigslist score
Thats awesome.....And i hear (some) prefer 2 bolt mains.....But i forget why.......lol
Awesome doesn't that feel good to have a solid motor?
I wish I had that feeling =D |
Junior Member
![]() Join Date: Jan 2008
Nice score!
1970 GMC 1500 Super Custom 1970 Olds 442 Convertible 1968 GMC 1500 Super Custom 2007 Honda ST1300 |
My Carbon Footprint
My 2 bolt main Camaro ran 12.35 in the 1/4 mile back in '86. 2 bolts are stronger than you think. A 2 bolt BBC is good for about 600hp.
400ci 2-bolts are the way to go.
what IS the motor??? a honda B18? you haven't mentioned!
RN U OVR |
yes, i do
its a 2 bolt 3970010 010 chevy 350 with a 040 overbore with flat top pistons and 462624 76cc heads
Next project: 1970 K10
I prefer 2-bolts myself. More meat in the web, plus if you really want the insurance you can add 4-bolt caps that have the outer bolts angle in to an area where.... there is more meat. Higher RPM's can cause the caps to walk around a bit, so GM felt the need for the extra bolts and bigger foot print of the cap-to-block. Usually this occurs from higher "sustained" RPM's, so it's typically not an issue. But I would rather build a 2-bolt block and add splayed 4-bolt caps than start with a stock 4-bolt block.
Either way, I'm probably at a point in life where whatever block I build off of wont ever be an issue. ![]()
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 11-24-2008 at 02:11 PM. |
that's what i thought... something about the splayed 4-bolts being bestest...
i think that's why the 4-bolt 400's are less desirable... the straight bolts are postitioned so that they compromise strength. so... splay that 350! nice score brother!
RN U OVR |
Tot Roddin'
Nice craigslist score!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
