Old 02-06-2003, 11:27 PM   #1
71-longbed
Its Magically Delicious
71-longbed's Avatar
Question brake question
my truck kinda hops when i apply the brake ..... i thought maybe 1 of my rotors needed resurfacing ....but they look good
any suggestions ???
71-longbed is offline   Reply With Quote
Old 02-07-2003, 12:52 AM   #2
crazy longhorn
Fabricate till you "puke"
you could have a warped rotor or drum, that would be something you would feel as a pulsing of the brake peddle, & will also feel like a shake, or vibration when the brakes are applied. good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-21-2003, 08:23 PM   #3
71-longbed
71-longbed's Avatar
thanks for the input
Old 02-24-2003, 02:56 AM   #4
outlaw
the best thing to do is have both rotors turned and replace brake pads, rotor warpage is not something that you can see with your eyes and once the brake pads get a certain wear pattern they keep that pattern so change the pads to
Danny
outlaw is offline   Reply With Quote
Old 02-24-2003, 01:15 PM   #5
68LSS1
68LSS1's Avatar
Sure you can. Use a dial indicator. We should all have one of these with a base, right?
68LSS1 is offline   Reply With Quote
Old 02-24-2003, 07:26 PM   #6
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Are you sure it's the front brakes and not the back? Sometimes a combination of a leaky wheel cylinder and loose spring bushings will make it hop irratically when the brakes are hit hard.
FYI to all
Harbor Freight has Indicators and Magnetic Bases on sale from time to time in their catalogs.
1" Travel .001 Dial Indicator on sale for $6.49
Magnetic base for Travel Indicator on sale for $6.99
The indicators are accurate and the mag base is identical to the one I just paid $22.00 for thru MSC.
A mag base and travel indicator is a great thing to have in any tool box.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 02-24-2003, 07:31 PM   #7
71-longbed
71-longbed's Avatar
im not sure if its front or back or a combination like you suggested .... i did try only braking with my parking brake which i know only applies the rear drums .... i didn't notice any pulsating or hoppin.... is this a good way to troubleshoot the problem or is there something im not aware of ....
thanks again for all the input
it helps alot
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
