![]() Join Date: Oct 2006
POWER STEERING , how long?
I wanted to do my power steering swap this Friday, and wanted to ask those who have done it about how long "should" it take?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Re: POWER STEERING , how long?
It all depends on:
your skill level if you have all the correct parts the tools you have I have done several power steering conversions on 4-5-6 Chevy trucks and it can be done in a long afternoon. If all goes well, it can be done in 6-8 hours. Surely, someone will chime in and say they can do it quicker, however I am not trying to win a contest to see who is faster, I just know how long it usually takes me. |
Cool LILRED.
I wanted to know if it could be done in a day , and who beter to ask then those who have done it. Im still debating on using my tilt or wating to do it when I re wire thanks
If you have the tilt column that matches your power steering box, that may save you some grief - already the correct length/connections
yeah it all depends on what parts you are using. I did our '66 in about the time frame Tony is saying, i used factory p/s steering brackets, had to raise the engine slightly to install them. I had to do some frame welding. found some cracks under the manual box. The truck already had the newer cross member and steering components. I did use the stock column, so I had to cut it down and weld it. oh and it takes a little bit of time to bleed the air out of the system also.
it is very do-able in a day
![]() ![]() Last edited by joe231; 11-26-2008 at 03:04 PM. |
Great !! I have the pump already instaled, and the p/s kit from CPP for my year 1960, hoses,belt and gear.
I'll post pics thanks again
Resistance is Futile
It goes easily enough; I had my whole front end apart so no idea about the time frame. I thought the hardest thing would be shortening the steering shaft and even that turned out well.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
64-66 CHEVY JUNKIE
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
1 thing at a time is progress.
It's taken me a year and a half and I'm not half way done yet.
Alan
Philippians 2:14-16 |
Hollister, CA.
![]() Join Date: Sep 2006
Wait a minute...I thought you had P/S already ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
I have the pump installed, but have not got around to installing the box, hoses and fixing the steering shaft
Hollister, CA.
I thought I seen a P/S pump on your sixer at the Alum Rock gettogether last time ??
I've done a few 60-66s. Just did a 62 with the 250 3 on the tree. That one was a PITA. Definetly doable in a day as stated depending on what all you want to do, ie column etc.
after
#15 |
ok help the new old truck guy out with a question. Why is your ps pump behind that other item in your engine bay? Every one I have ever seen is on its own bracket off of the belt drive track. Thanks and sorry again for the rookie question.
Juan |
#16 |
Juan |
#17 | |
ok here is an up date. Old gear is out ,addapter and new gear mounted, steering shaft is cut. As allways, I did run into a few problems, old pitman arm needed a lot of coaxing to get it out. 2nd ,the addaptor plates instructions were a bit "off" it said to drill out the lower front bolt hole on the new gear, I found out that on the 60 I had to drill out the upper hole on the rear. And 3rd my pitman arm on the donor gear is not leting me tighten it up, so I'll get a new one tomorow That said it wasnt bad I still need to install the hoses, and get one bolt to finish mounting the box. I also need to install the steering shaft, and get that pitman arm and bleed it . I know I said i was going to do this Friday but who wants to watch the Lions play? anyways I took some pics, and will post them when all is done. Thanks to all who said it was an afternoon job it is.
#18 | |
Registered Asphalt Offender
![]() ![]() 1963 C10 Short Fleetside Bed Big Back Glass 1974 C10 Short Stepside Bed 1982 S10 Shortbed 350 EFI V8 http://67-72chevytrucks.com/vboard/a...hp?albumid=140 http://www.hubgarage.com/mygarage/MEANlowGREEN http://www.motortopia.com/garage/cars/MEANlowGREEN http://www.myspace.com/jcsmeed |
#19 | |
That is a rare generator/power steering unit from the tri 5 chevys. I believe it came on 58 and 9 cars too. The p/s pump and brackets for the 250 "stovebolt's" are like hens teeth to find. I did find a set of brackets for the 250 but decided to use this instead since I found a rebuilt unit fairly inexpensive. Had to custom make the mounts and rebuild the generator. Worked awesome!!! |
#20 |
well like always, something came up. I need to replace the pitman arm, but I didnt want to wait to get one from work on monday, so I orderd it from a local parts house.
It will be in at 11 am they told me . So in the mean time I installed the hoses, worked on the steering shaft, and finished installing the box. I called to see if my pitman arm had come in,nope. The driver left it at the wharehouse, It will be in at 12:30 , so I waited . At 12:30 I get a call "your BALL JOINT is in , yup ball joint..... So now I have to wait till tomorow. any ways any tips on installing the pitman arm ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 11-29-2008 at 01:06 PM. |
#21 |
all done !! I will post pics soon
#22 |
cool....
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#23 |
well....you know what is coming........
#24 |
yea yea yea.................
here are the components and new gear and the old gear
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 01-14-2009 at 06:57 PM. |
#25 |
the old gear is out, no problem with the frame......
the addaptor plate installed
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 01-14-2009 at 06:58 PM. |
