Old 11-26-2008, 10:21 PM   #1
nonoboys
need help installing tahoe seats
I got the 2nd row seats out of a 96 tahoe. There the 60/40 split. Can anyone give me detailed instructions on how to install? Thanks.
nonoboys is offline   Reply With Quote
Old 11-27-2008, 09:16 PM   #2
OrrieG
OrrieG's Avatar
Re: need help installing tahoe seats
Do a search on "seat install" There are a bunch of threads with good info on installing 2nd and 3rd row seats in Blazers, Suburban and Pickups, front and rear situations. You can look and see which way works works best for you. Some replaced the whole floor pan, others used factory brackets, others fabed brackets. I went through the same drill for my Yukon seats and am going to fab some brackets that let me tilt the seats forward and remove them for access to the stuff that I'm putting under the seats.
Old 11-27-2008, 09:54 PM   #3
msgross
msgross's Avatar
are they like these?
http://67-72chevytrucks.com/vboard/s...d.php?t=128033
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-27-2008, 11:01 PM   #4
nonoboys
That looks like them, Mike
Old 11-28-2008, 12:49 AM   #5
mitch1965
mitch1965's Avatar
I installed the front seat from a '96 Silverado into my '85 K20. To do this, I had to remove the '96 mounts from the seats, and fabricate a frame to tie the 60/40 together. I then fitted it onto the '85 slide mechanism in the truck, marked it, and welded it into place. I did find that I needed to mount the seat farther back on the mechanism, with the back more upright, than I really wanted. I did this to provide the legroom and adjustability I want.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73
'01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10
mitch1965 is offline   Reply With Quote
