Old 11-28-2008, 10:58 PM   #1
crazy longhorn
Fabricate till you "puke"
Re: what are some easy cheap fixes to make your truck look better
2 " drop block (rear), & 1 full ring cut off the bottom of the coils up front......that will get the 'stance" closer to right crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
