09-28-2008, 07:47 PM | #1 |
Navy Radioman Veteran
The lowrider left me stranded today!
I had been out cruisin' today, went to wal mart and all was fine. On the way home from the store, the truck fizzled out and wouldn't start. No fuel pressure on the gauge. So I'm guessing the pump is out. Pump not making noise when the key is turned like normal. Dont know if it's a fuse but all the fuses on the panel look ok.
Had it towed home. Will dig into it next week. Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 |
09-28-2008, 08:01 PM | #2 |
Re: The lowrider left me stranded today!
Well that sucks. Electric pump, eh? What brand? I have a Holley blue pump... so far so good.
- Greg |
09-28-2008, 08:29 PM | #3 |
Old Heap Driver
You have a carb on the BB, correct? If so, dump the electric pump and get yourself a mechanical pump.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
09-28-2008, 08:56 PM | #4 | ||
BTW... it was a blown fuse ECM2 on the box... IT'S A L I V E again!!!
09-28-2008, 09:23 PM | #5 |
Dually Pride
good thing its nothing serious, just sucks you had to get towed home..
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
09-28-2008, 09:34 PM | #6 |
oh well... no biggie... didn't have any fuses anyway or my reading glass to read the itty bitty letters on the fuse panel to see where the fuse was for the ECM anyway.. I guess I should take both next time I go out huh?
THANKS FOR ALL THE HELP AND IDEAS ON THE CHAT SITE!!! MY OFFICIAL NEW HANG OUT! Kenny
09-28-2008, 11:05 PM | #7 |
Chevys Kick A$$
Thats sweet that you got it running again too bad you had to get it towed home. Glad it was nothing major!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
09-29-2008, 12:21 AM | #8 |
thanks!
09-29-2008, 12:26 AM | #9 |
Sb 400 club
good to hear she is back and running again.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
09-29-2008, 04:27 PM | #10 | |
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
09-29-2008, 06:24 PM | #11 | |
Someone recommended the Mr. Gasket pump at Advanced Auto and a couple filters inline in place of the factory pump which is the tank now. Ken
09-29-2008, 06:28 PM | #12 |
Old Heap Driver
Are you using a "By-Pass" regulator? If not, the pump will heat up. A By-Pass reg will keep fuel flowing back to the tank and into the pump, cooler pump.
09-29-2008, 06:33 PM | #13 |
Yes.. I am using a bypass reg. I'm in the chat room www.67-72chevytrucks.com/chat.html
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 09-29-2008 at 06:39 PM. |
09-29-2008, 06:39 PM | #14 |
Old Heap Driver
Wasn't sure, I remember the build up thread. I was just too lazy to look for it. LOL.
Oh well, I blew a fuse for my pump a while back, roll-back time. LOL. Planning on going mechanical soon.
09-29-2008, 07:14 PM | #15 |
I'd have to go back to the thread and see why I elected not to use the holley mechanical pump.. I still have it.
10-03-2008, 08:13 PM | #16 |
Well, I talked to my mechanic today who I use when I get into something over my head or don't have time to mess with. He said that the fuel pump only pumps 9-13 psi. I've also noticed some electrical issues when I turn on the turn signal. I found that when they stop working, so do the electric windows.
I'm not convinced there's not a wiring issue in the harness.. maybe a short somewhere and or maybe a bad ignition switch. I did notice the other day I moved the key and every light on the dash, went black and the engine even stuttered for a half a second. Thoughts??
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 10-03-2008 at 08:15 PM. |
11-29-2008, 12:03 AM | #17 |
UPDATE: Found the problem, finally!
I finally got the time to take truck to the shop and get it up on a lift. We started looking for wiring problems first. We found the fuel pump wiring harness on the left side had fallen down on top of the muffler and welded itself to it. Everytime, I'd put a fuse in, it'd blow. So, 1 problem solved. Started the truck and got it up to temp. Revved it a couple times and blew the circuit again. Chased harness, no other problems noted. Fuel pump is bad as it pulls major amps and blows circuit in the process. Installed a new Holley HiPerf manual pump on the block without the regulator. Pulls 12lbs of pressure through the existing electrical pump still in the tank. Had to put the regulator back in line and regulate the pressure back down to 5-7 lbs for the carb. Runs like a champ!
