Old 11-30-2008, 03:50 PM   #1
liljimsrodragz
Easiest way to lay rocker
Hey there,
Just got a 70 chevy s/w with a 68 nose. Its in pretty good condition and I am going to try and convert it to 72 front suspension so that I can get the five lug disc brakes and then use a 72 rearend. Trying to just find a donor truck.
Anyways, the a-arms have been modified for a two inch drop so does that rule out drop spindles? I have heard they cause problems when both are combined. Other then that whats the easiest and cheapest way to lay the truck as close to the ground without doing a body drop.
Willing to do c notches in the frame if thats the next step but what about the front. Thinking about air ride but its just a shop truck so trying to do it on the cheap. The theme is real low and ratty with nice big wheels.
Thanks, James
liljimsrodragz is offline   Reply With Quote
Old 11-30-2008, 04:51 PM   #2
Painter D
Painter D's Avatar
Re: Easiest way to lay rocker
There is no "easy" or "cheap" way to lay rocker.
You mentioned your control arms have been modified for a 2" drop, what's been done to them? I would assume they've been stepped. Also if you want it to be that low you'll probably have to look at putting some kind of air ride on it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-30-2008, 08:39 PM   #3
liljimsrodragz
I understand that there is no Easy or Cheap way out and thats why I asked the EASIEST way that it could be done.
Old 11-30-2008, 08:50 PM   #4
56fleetside
///RELAXED ATMOSPHERE
56fleetside's Avatar
Easiest way is to place a order with Poterbuilt or Suicide Doors and order their front and rear bolt in setups...........
Like a BOSS
56fleetside is offline   Reply With Quote
Old 11-30-2008, 08:53 PM   #5
scotts62
One day...
scotts62's Avatar
You could probably get it as low as 69chevyshort without doing a body drop. Making a notch in the back would make room for the clearance and you metioned you already had moded the control arms,that just helps getting it a little lower. if you got dropped spindles that would lower it more. Are you using the stock trailings arms or redoing back half?
Scott
93 crew cab build
Project 62
Old 11-30-2008, 09:43 PM   #6
FnLow69
FnLow69's Avatar
first laying rockers with big wheels wont be easy or cheap no matter how you look at it. Second it depends on tire size to see what exactly needs to be done. but either porterbuilt frontend or Z'd frame (z'd frame requires raising the trans tunnel) with bags up front and notch and link setup (2link or 4 link)and bags out back. Then you will need to drop the cab mounts one inch and cut the pinch to lay the rockers on the ground
FnLow69 is offline   Reply With Quote
Old 11-30-2008, 09:48 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Easiest way to lay rocker is cut them off and throw them on the ground. Sorry but I couldn't help my self.
Like mentioned above, there aren't any "cheap and easy" ways to get that low that any one here will recommend. You can get pretty low with out too much expense, but getting the rockers on the dirt is a big jump in time, materials, cost, and labor.
This is as low as you can get with out spending the big bucks.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-30-2008, 09:51 PM   #8
Painter D
Painter D's Avatar
Agreed
This would probably be the easiest way to go. I wish I would have.
Old 11-30-2008, 09:55 PM   #9
Mrwlliam
Is that all? HAHA great advice guys! N2Trucks.. that is a sweet ride. what do you have done exactly?
Mrwlliam is offline   Reply With Quote
Old 11-30-2008, 10:28 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
It all depends on how much work you want to get into
In order to lay frame you are gonna run into a lot of clearance problems, like tire to firewall clearance & you pretty much have to remove your heater, inner fenders, cut your fenders, cut up your bed
I opted not to lay frame on my driver because of how much extra work & money it was gonna be, and laying rocker is even more
But like said, the easiest way to lay is to buy some Porter Built Drop Members
And the cheapest (if your time is worth nothing) is to Z the frame front & rear (you could also do a big notch in the rear)
Just check out my thread for Killer in my sig
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-30-2008, 11:42 PM   #11
Bazooka
Keepin it old school
Bazooka's Avatar
This is what im using
http://67-72chevytrucks.com/vboard/s...d.php?t=309092
Last edited by Shane; 12-01-2008 at 01:53 AM. Reason: you need to subscribe in order to advertise
Bazooka is offline   Reply With Quote
Old 12-01-2008, 02:40 AM   #12
liljimsrodragz
That is plenty low enough. I am just building this truck as a daily driver, parts hauler type shop truck anyways so I dont need anything real elaborate. Just something the looks cool ya know. What did you do to get your truck this low?
Thanks, James
Old 12-01-2008, 07:08 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
To answer one of the original questions, no, you can't use dropped spindles with the stepped A arm. You can put a lowering spring in there though.
Kinda funny how you never said anything about "laying frame" or "laying rocker"... yet, that's what everyone is talking about.
Old 12-01-2008, 08:28 AM   #14
scotts62
One day...
scotts62's Avatar
Well the headline of the thread is "easiest way to lay rocker".. kinda think he said it sometime
Scott
93 crew cab build
Project 62
Old 12-01-2008, 11:43 AM   #15
liljimsrodragz
I think I would rather just cut the original springs to the length I need and run a stiffer shock. I dont want to spend a whole lot of money on it, I need the money for my full frame nova project. Just want something cool looking to drive everyday.
Old 12-01-2008, 12:17 PM   #16
scotts62
One day...
scotts62's Avatar
Then do like a mild drop some nice wheels and cruise it
Scott
93 crew cab build
Project 62
Old 12-01-2008, 01:04 PM   #17
Mrwlliam
I will need to be a paying member :wink wink: before I solicit sales.
Attempting to buy & sell by way of PM's without subscribing will also earn me a BAN.
Consider yourself warned.
Old 12-01-2008, 01:19 PM   #18
scotts62
One day...
scotts62's Avatar
Mrwlliam, Careful asking around for selling they want you to subscribe to do that legally, just rules of the fun i guess.
good looking truck by the way
Please don't encourage members to break the rules....
Scott
93 crew cab build
Project 62
Old 12-01-2008, 01:37 PM   #19
Mrwlliam
Thanks for the catch.. I fixed it
Old 12-01-2008, 03:35 PM   #20
scotts62
One day...
scotts62's Avatar
There ya go, no prob
Scott
93 crew cab build
Project 62
Old 12-01-2008, 04:25 PM   #21
liljimsrodragz
Well I want it about the ride height of the orange one. I am more then willing to do an air ride setup but its got to be on the cheap. Like under a thousand bucks....nothing fancy just something thats functional. I would like to do c notches in the rear but thats about as far as I want to go. Its already fairly low....in fact its about as low as the grey truck is in the front but it sits farely level. So somewhere in the neighborhood of the orange truck would be nice.
Old 12-01-2008, 04:37 PM   #22
scotts62
One day...
scotts62's Avatar
on the back you could put the bags where the coils springs go and do a c notch, front just get cups and the plates that cover coil spring pocket on bottom side of crossmember,then you just decide on what valves, tank and compressor you want to run. if your just going to have air ride the simpler way thats what i would do.
Scott
93 crew cab build
Project 62
Old 12-01-2008, 05:54 PM   #23
Mrwlliam
Ball valves and one 3 gal airtank/1 comp. set up would work.
fairly cheap. tank $50.00
bags $80.00 each(unless used.)
comp. $200.00 (maybe)
Mounts $200.00.
And how ever much ball valves and air line would be.
Ive yet to see a ball valve setup look good though. Anyone else?
Old 12-01-2008, 09:20 PM   #24
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
IIRC that is aired out on the orange one
Sinister
Killer
Old 12-01-2008, 11:30 PM   #25
liljimsrodragz
Mounts $200.00.
What are the ball valve setups? And I am guessing there some other type of valve then?
Whats a good size and brand of air bag to use?
THANKS, James
