Re: Turbo 350 NP205 Leak
did a search and found the same advice. Thanks.
Actually there are 3 seals. Been there done that. There are 2 seals on the outside diameter of the coupler (these are the likely leak path). Pay attention to the direction they are installed since they are backwards from what you would normally see.
Third seal is a thick o-ring on the NP205 input shaft which seals with the inside diameter of the coupler. |
#3 | |
Grease Monkey
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
I see I;m not the first. Thanks for the good info. Just got it back on the road. will most likely wait a week or two before tearing it down. Need to fix or replace a leaky power steering gear box first.
