Another question for you guys I,ve heard you could put cadillac rear disc brakes on our model trucks. Is anyone done this and could maybe tell how it,s done? Also maybe show some pictures?
member #16
![]() Join Date: Dec 1999
Re: cadillac rear disc brakes on 70 truck
Heres a link to a CCP article.
http://www.classicperform.com/tech_a...kes-trucks.htm
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Is there a way to do this without buying a kit? Maybe use rotors and calipers off the cad?
Its always something!
I am using a 76-79 seville rear under my 72. It keeps the 5in bolt pattern & is already set up to sit on top of the leaf spring.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() Member of the patina club |
Restoring a 68 SWB
What gear are usually in the Seville's, and is the rearend the same width?
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
i am currently using 1986 caddy seville disc brakes in the rear of my 72 burb. kept same 5 lug pattern and still running mid 80's steel wheels.
86 seville had rear disk brakes that uses rubber brake line with a 10mm x1.50 banjo bolt. i am using stock 72 burb rear end with the caddy backing plate and brake setup. the only problem you will have is the parking brake cable but, POL (performance online.com) has solved this issue and makes the correct lenght cable when using caddy disc brakes. I pieced my setup together, but POL makes a kit for 67-72 trucks to run caddy rear disk brakes.
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 Last edited by 61superman; 11-15-2008 at 05:33 AM. Reason: update |
61 Superman do you have any pictures? This is more of what I,d like to put on mine.
68 longbed i have none as of now but i will try to take some pics tomorrow.
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
If you dont care about an e-brake you could use the impala set up or if you do want and e-brake you can use the camaro calipers. Here are a couple pics of my impala setup.
Ram-man what year impala brakes you using?
Texas Big Wig
I have rear discs off a fleetwood, I think it was a 76 or something
I havent gotten them installed yet, but as far as I know its pretty strait forward & you just swap the backing plates for the caliper bracket & bolt the rest of the disc stuff on Also this may help you find some discs, its a list of 5x5 compatibility http://67-72chevytrucks.com/vboard/s...d.php?t=234769 Last edited by Spray-Bomb; 11-17-2008 at 09:08 PM. |
Old Skool Club
![]() Join Date: Jun 2001
Isn't the early Seville based on the same era Nova? Not that it matters, mind you. I'm just trying to reach back into some of the cracks and crevices of my damaged brain for some tidbit of trivia.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Mid 90's rotors and calipers. The cores for the calipers are expensive so try to hunt some old rusty ones down to turn back in for the core charge.
Here is an old thread on this. http://67-72chevytrucks.com/vboard/s...ghlight=impala |
#15 |
68 longbed i apologize brake booster went out and been working sick overtime trying to support my habit will try extremely harder this weekend
once again i apologize
#16 |
Superman didn't mean to rush you. I'm trying to make up my mind on which way to go caddy (which I'm leaning towards)or the impala route.Caddys are more pleneful in this area.
#17 |
alright 68 longbed again i apologize but here is what you were asking for:
this is my setup 85 cadillac seville calipers stamped 020,021 77 cadillac seville rear rotos (mine are just drilled) banjo bolt 10x150 the cadillac rubber brake hose is metric for it to bolt up to your hard line you will need an adapter from metric to standard (got mine from napa). hope this helps and if you have any questions i promise to get back with a speedy response. hope the wait was worth it
#18 |
What application is the caliper mounting plate from? And does it bolt right up to the backing plate flange? Thanks
#19 |
Post #6 says he is using the Caddy backing plate, actually the entire Caddy setup. With an aftermarket parking brake cable and adapters for the brake line.
#20 |
i am using 79 deville mounting brackets also i need to mention that the seville and deville rotors are the same for a number of years therefore can be interchangeable. as i was developing this brake setup there are several possibilities to choose from these are just what i had lying around and scavenged from friends.
here are some of the part numbers that i have that are stamped in the metal are: 1610797 rotors (stamped on back) 1613827 brake mounting bracket (stamped on front) 020 and 021 calipers passenger and drivers these numbers are gm specific final note: again this is just what i went with, please research info before spending time and money on your brake setups good luck
#21 |
Any idea where to get those brackets? Besides the junkyard?
#22 |
i called chevy dealer and they said that they were no longer available. thats about the only way i know. CPP and POL both have kits that allow this type of setup they might just sell that mounting brackets wouldn't hurt to ask them. here are some other options:
good luck
#23 | |
#24 |
the rotor is about an inch thick
good luck
#25 |
79-85 Eldorado, Riviera, and Toronado and 80-85 Seville.
Piston Diameter 2 1/32. Opens to 1.050. 5 1/2 inches pin to pin. BENDIX Part # L55312 Rear Left Caliper with Pad; Contains CQ ceramic pads $91.79 $15.00 $106.79 BENDIX Part # L55311 Rear Right Caliper with Pad; Contains CQ ceramic pads $91.79 $15.00 $106.79 Maybe this helps www.rockauto.com Mick Last edited by MickMc; 12-02-2008 at 05:13 PM. |
| Bookmarks |
