11-24-2008, 11:19 PM | #1 |
LMC Antenna question
i bought this antenna through LMC and it does'nt seem like my old original one. it seems it has more of a slope to it and i think that it would chip the paint once it is tightend down. the part number is 38-1156, it is the "repro-telescopic antenna". What do you guys do for antennas?
11-24-2008, 11:58 PM | #2 |
Active Member
Re: LMC Antenna question
I bought an aftermarket for mine (didn't fit real well) and it had an adjustment for the angle. On the one I bought, I had to loosen a screw from the bottem and twist the two angled parts until I got the correct angle.
Yours looks like it has some flattened sides on the top piece. Maybe you can loosen that with a wrench and turn and twist until you get the correct angle. btw: some guys have bought from one of the vendors not sure which one and got the exact replacement antenna. |
11-25-2008, 12:07 AM | #3 |
Moderator
Is the antenna made by Counterpart?
11-25-2008, 12:33 AM | #4 |
no i dont think that it was made by counter part.
11-25-2008, 12:39 AM | #5 |
Moderator
I have one that is made by Counterpart....fits perfect. They sell at www.truckandcarshop.com for $40-$50 I got mine from Classicbowties (Mel) here on the board. You can pm him, as he sells them also.
11-25-2008, 06:13 PM | #6 |
all righty thanks a bunch!
11-25-2008, 08:07 PM | #7 |
Are you sure you have the factory hole?
12-01-2008, 05:40 PM | #8 |
yeah, i have the factory hole in the cowl, i did not take the cowl off because i was almost positive it wouldnt fit right.
12-01-2008, 11:46 PM | #9 |
Is there an aftermarket windshield available with an antenna??? I like the idea of a filled cowl panel.
