11-29-2008, 08:08 PM | #1 |
Alternator wiring?
I posted in the electrical section, but I want to see if anyone else can help that has possibly dealt with this issue. This is my original post http://67-72chevytrucks.com/vboard/s...d.php?t=314935
What I have. Delco 12si alternator New EZ wire harness New battery Issue I have. I turn key on (not run), no Generator light. Engine start give it rpms and the Gen. light comes on and the alternator is charging, 14.34v at idle and 14.41 with rpms. This is voltage at the battery. Once light is on it stays on until I shut off engine I currently have the power Alt wire (red) to the back lug of Alt. and then jumping to the #2 terminal. My excitor wire (white) going to the #1 terminal. |
11-30-2008, 04:15 PM | #2 |
Re: Alternator wiring?
Anyone?
11-30-2008, 05:05 PM | #3 |
Sierra Grande Club
shooting in the dark but here's some info I had......http://www.madelectrical.com/catalog/alt-1.shtml
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
11-30-2008, 06:50 PM | #4 |
I think at this point I will just bypass the Generator light. How should I wire in a voltage gauge to get true alternator voltage?
11-30-2008, 11:55 PM | #5 | |
Sierra Grande Club
s/t
12-02-2008, 12:40 AM | #6 |
Gone to greener pastures
Just wire a voltmeter to a switched source on your fuse panel.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
12-02-2008, 03:32 AM | #7 |
"THE GREEN GOBLIN"
ttt
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
12-02-2008, 02:01 PM | #8 |
I am in contact with EZ trying to figure out if my wiring is correct. Hopefully I'll get it figured out.
I might put in a voltage gauge too, after this. |
