ece trailing arm crossmember
has anyone ever installed a carrier bearing in one of the ece dropped crossmembers for the trailing arms. if not how are you long bed guys getting these things to layout without dragging the factory one.
3DrDwn--the 'burb not the band
Re: ece trailing arm crossmember
the consensus is to cut the bottom of the stock member flush with the frame and plate it to retain strength. it's also a good time to mod the x-member for the exhaust to pass through.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
i think i saw someone on here do that. is there anyone out there that has the pic of that. thanks a lot for any info guys and gals.
PorterBuilt Man Crush
![]() Join Date: Jul 2007
you can do it, I have one, and was going to install an empire driveline carrier bearing in it. Stan at ECE has also done this on an Overhaulin truck they were part of.
The 72 will live again |
