Old 02-25-2003, 07:46 PM   #1
longbowdude
Question '72 GMC Jimmy fuel guage problem
The sending unit on my Jimmy was changed by my father shortly before I bought the truck from him and there is still a problem. The guage pegws itself at the 3 o'clock position and doesn't accurately show the fuel level. Do I need to change the sending unit again or is this more likely an electrical problem??
1972 GMC Jimmy 4X4
350/TH350/NP205
longbowdude is offline   Reply With Quote
Old 02-25-2003, 07:55 PM   #2
JimKshortstep4x4
Talking
If you unplug the sender, the gauge should read well past full. If you ground the brown wire from the sender, then the gauge should read empty. If that is the case then the problem is in the sender unit, sender grounding or the wire from the back to the front. The sender actuates the dash gauge by "grounding" it in effect, so if the sender is not grounded completely then the gauge can end up anywhere.
An easy location to do your gauge tests is at the fuse panel as the wire from the sender plugs into the panel.
Jim
Old 02-25-2003, 08:00 PM   #3
longbowdude
sending unit
Thanks Jim,
You probably just saved me an entire weekend of troubleshooting.
1972 GMC Jimmy 4X4
350/TH350/NP205
Old 02-25-2003, 08:03 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
I just had the same problem with my snow plow truck. I turned out to be the wire between the fuse box and the sending unit. I replaced it and now I have the option to run out of gas on purpose.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-25-2003, 11:39 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Common place for that wire to short out is under the chrome trim at the bottom of the door.
