87 to 73 front end swap?
i know its possible have read about it, i would need differmt hood,fenders,inner fenders, radiator support, and what els? i found a used 3/4 ton that is being parted will that 3/4 ton work with my 87 c10? the 3/4 ton is 4x4 to.. thanks for any help.
It Is What It Is,,,,
Re: 87 to 73 front end swap?
I was looking into for my self. Your gonna need just about everything for the front. And for the hood hinges, you have to mod the fire wall for the hinges.
But the swap looks bad azz!!
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
putting a 73 front in on a 81-87 is a piece of cake. If you have a donor unbolt EVERYTHING that attaches to the 73 and bolt it on your 87.
You WILL need the COMPLETE wiper assembly that is bolted to the 73 cowl though and will need to "fix"/drill holes in the 87. You will also have to fix the bumper mounts at the frame horn. (and get the 73 bumper. 4x4 doesn't matter, it is the sheetmetal you want and it is the same. If you want it looking "correct" weld a cover over the 81-87 hinge hole. Not required though. You do not need to modify the firewall for hinges to put a 73 front end on an 87, the 73 hinges bolt to the fenders.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
