![]() Join Date: Jun 2007
Dashpad Repair Idea
I have an idea and want to know what you guys think about it. I'm thinking about making repairs on my dashpad with some fiberglass or bondo to fix the cracks like I've seen some of you guys do, and then take it, and an old set of door panels that I have to either Line-X or Rhino Lining and have them sprayed with bedliner.
It wouldn't have to be sprayed on as thick as the inside of a bed, just enough to get good coverage. Since you can have that bedliner material tinted to your specific color and it is tough as hell it should look good and last a long time as long as it would adhere to the dashpad and door panels. Has anybody tried this? If you have, what was the result? Good idea or not? ...Joe
I'm not speedin'! I'm qualifyin'! |
Re: Dashpad Repair Idea
currently i'm attempting to fix mine...i stripped all of the old vinyl off and filled in all the cracks w/ great stuff foam...gonna shave it down and fiberglass over it...we'll see how it turns out, so far i'm just having some issues around the little parts, but i haven't gotten a chance to work with it much.
Should work fine, theres a 67 or so bronco around here that's totally covered in linex, inside and out. Everything except the glass, seats and some chrome trim they kept.
Chevys Kick A$$
I think it should turn out decent. Let us know how it works out for you. If you get a chance to post pics that would be sweet too.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
There's a Line-X dealer not too far from me in Ozark. I'm going to give them a call and see how much they would charge to do it, and if they even will. I'm thinking about doing the door panels first to see how they would turn out if they'll be willing to do it.
If I'm able to get it done, I'll post up some pics. I don't think that it would take that much material to do it really. Just enough to cover and get a decent texture would be all that I would want. Not sure if I would need to tape up some areas such as around the door panel inserts and the chrome trim so that I wouldn't have so much buildup that I wouldn't be able to get the parts put back together. I'll just have to talk to them about this idea and see what they think would be the best way to do it. ...Joe
Did you ever do this how did it turn out
