This my 67 longbed setup. The pictures are when its layed out, the bars are parallel at ride height though. any feedback? besides the crappy tack welds lol.
[IMG] ![]() [IMG] ![]() and a little picture of what it used to look like ![]() [IMG] ![]() |
One day...
![]() Join Date: Apr 2008
Re: My watts link setup...what do you think?
Sweet!
Thanks guys, ive been checkin out both your projects, and both of them are sick. Spray-bomb, hows that cadillac monster comin?
I got it from my friend Rich, He has a fabrication shop just a couple miles away. |
Texas Big Wig
Oh the drag truck is just sitting waiting its turn
![]() I dont have the money, time, or space to work on it right now ![]() |
THE TOY STORE
will the bushings not allow wobbling?
3DrDwn--the 'burb not the band
those bushings are stronger and firmer than what you'll find in a stock leaf spring so I think it'll do just fine.
Sounds like you got the important part about the bars parallel to each other and the ground at ride height. Some will tell you that it is better to have the center pivot mounted to the frame and the bars to the axle and it is but I have done several similar to your set-up and they all worked out ok. My old shop truck was a 1ton dually that I ran a watts on and used it to tow like nobody's business and it's still in service. Looking good, Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
Looks good.
I used poly bushing and heim joints on mine and never had any problems. ![]()
clint- did you ever finish your C10? can't wait to see it.
-mike
-mike |
Went to a new home in the bay area to a guy who "had to have it". I've since moved on to another early model C10 that will be surfacing in 09 if all goes well.
later
Looks good man.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
I think it looks good. Why the bushings at the axle though?
A guy with a truck
What's the depth of the KP piece- i.e; how far past the diff cover does it protrude?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Easy way to mount it.
It looks good. A little far from the axle for my taste visually, but it should work great.
If you can find it cheaper, I can fix it! |
#15 |
It's was designed to be snug as you can get it to the diff cover, and sticks out past it appx 2.0 - 2.5 inches.
#16 |
![]() Join Date: Apr 2004
fyi, on my 2wd blazer i had to mod the crossmember between the rear and the gas tank. i have the kp watts.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#17 |
Blazers have a different crossmember location behind the axle than the trucks, and we designed it to work on the truck chassis. We didn't have a blazer to test it on, and I appericate your helpful information. I will not that when working with early model blazer owners.
Thanks again for the info. Clint
#18 |
A guy with a truck
homi- did you ever get any pics of your final configuration? Curious to see how it worked out for you.
Side note- how do these perform on an uneven surface, i.e; entering a driveway at an angle? That was the only time my old panhard setup would rub.
#19 |
Thx for the comments guys. Its my first truck and its cool to hear from some of the pros
![]() yeah it is a little far from the diff cover, but if i ever need to take it off it will be easy to get too haha |
#20 |
No pictures, but it looks just like the KP that was posted. Where would the panhard rub? I've had no problems with mine except for the unforeseen crossmember issue. Its never rubbed on anything and I've scraped just about everything else at one time or another when I'm too low for the conditions.
#21 |
A guy with a truck
With the 20x10s out back, when entering a driveway at an angle, the tires would rub on the inside of the tubs just slightly. I was just wondering if it would get in any kind of bind when the axle is articulating like that, or keep the axle relatively straight.
#22 |
I get zero side to side movement between all the way aired up and no air at all. I don't think it moves at all.
