I have a 1964 c10. I just finished my front 5-lug disc brake conversion. I changed the ball joints and used 1984 suburban parts. Can I just swap the axles out of a 1972 c10 to get a 5- lug pattern. are the axle lengths the same from 1960 to 1972.
A guy with a truck
Re: read 5-lug conversion
No. The axles on the '71-up trucks are 3/4" longer. You will need a conversion axle or swap the entire housing...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Thanks, I believe the bolt pattern would be the same 5 on 5. Is this correct.
Tags |
i have |
