12-05-2008, 10:01 PM | #1 |
how low can i go?
with 20's on my truck!
im wanting to order some new coils but i want my truck low, so how low can i got with 20's on my truck? |
12-05-2008, 11:32 PM | #2 |
Re: how low can i go?
you can lower it as much as a truck with little 15's as long as you use the right rim and tire.
12-06-2008, 02:16 AM | #3 |
Fabricate till you "puke"
Figure about 3" drop on the front, & 5" rear drop on springs ......before you start cutting things up! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-06-2008, 11:01 AM | #4 | |
Tot Roddin'
You can also run bags and go lower, but will require a little more modification to your truck. Check out Suicide Doors and Air Ride Technologies for different bag setups. SD will offer great products at a lower price than ART.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-06-2008, 11:02 AM | #5 |
Tot Roddin'
I'd try to run some type of lowering spindle (2.5" drop) to help keep the factory specs on the front suspension.
12-06-2008, 11:35 PM | #6 |
here's mine 5/6 with 20's
