![]() Join Date: Feb 2008
Re: Air Duct Selector Switch Question
Longhorn Man,
That makes sense because it is "kicked on" when you move the control from heater to AC. Do you have any idea where I can get a new one? Thanks.....I knew you would have an answer for my question!!! |
Today I had a chance to run by NAPA...they didn't have it but recommended a dealership. Dealership had a guy at the parts counter that had been there since 1970 and had never been asked for this part. He steered me to a division of Modern Chevrolet in Winston Salem, NC called Classic Muscle. They had the part (repop) and it was reasonably priced. The part is called "Air Conditioning Compressor Clutch Actuating Switch". If you ever have any hard to find parts, you might try them....OldMuscleCars.com
Thanks Andy for the help...it got me started to a solution. |
Active Member
![]() Join Date: Dec 2003
I'm pretty sure that LMC has this switch. You can also try the vendors on the board I think some of them should have it. That switch is not an uncommon item in the A/C section of most catalogs.
Old member
That switch is common in A/C work. It's just a on/off switch to cut the compressor on. I have my electric fan hooked to it also. The fan will come on anytime the compressor is on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
