02-16-2002, 07:58 PM | #1 |
2 wd to 4 wd question
In another post on the 67-72 board someone posted that these model trucks have the hole already made into the frame for 4x4 axle in front. do the 73-87's also have them?, I'm getting a 78 crew cab 2 wd, and a 80 k-10, how hard is it to put the 4 wd axle under it?The crew is also a granny 4 how would I do the trans fer case? thanks ,
conoverbandit
71 GMC 3/4 ton converted to dually 75 chevy swb 4x4 78 pontiac trans-am----sold, so long old friend..... 87 Crew Cab 2x 454 93 chevy hi top conversion |
02-16-2002, 10:10 PM | #2 |
conover, I'm not sure what you are refering to about the "hole for front diff or axle". 72 era 2x and 4x frames are different. I don't know if the frame rails on a 73 & up 2x are the same as a 73 & up 4x. As for the trans and transfercase - the output shaft is different on 2x transmissions, so you would have to use a 4x4 tranny setup. Hope this helps! Good Luck, Rob
02-23-2002, 12:51 AM | #3 |
the holes are there,however you have to remove the front crossmember and move it too. It is a lot of work
------------------ 69 CST/10 350/400TH lwb fleet all original,1 owner 79 K/20 4x4 built & lifted Sheridan,IN
69 CST/10 350/400TH lwb fleet,1 owner 79 K/20 built & lifted 85 K/5 4" lift 6.2 Diesel Sheridan,IN |
02-23-2002, 09:21 AM | #4 |
Its more bother than its worth.
