Old 12-09-2008, 10:31 PM   #1
theyammieguy
accepting donations
theyammieguy's Avatar
6 lug disc to 5 lug disc
I have disc up front in a 6 bolt pattern, is it as easy as buying a 5 lug rotor to do the swap? If so which rotor would I need?
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 12-09-2008, 10:34 PM   #2
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: 6 lug disc to 5 lug disc
72 i believe was 5 lug would be the simplest.
i got a 75 front end on mine somehow. just came home that way.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 12-09-2008, 10:43 PM   #3
theyammieguy
accepting donations
Pretty sure mine is the stock crossmember but have no idea what brand conversion kit was used.
David Crockett
Old 12-09-2008, 10:47 PM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
i would think so, you could pull a rotor and take it with you to the parts store and have them mic the 6 lug vs. 5 lug, if the same inner diameter you should be able to bolt up.
if you were not several hours away, i would let you test fit some stock rotors i have in the garage.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-09-2008, 10:49 PM   #5
theyammieguy
accepting donations
I might head to the junkyard on saturday and take a few measurements.
Thanks for the offer.
David Crockett
Old 12-09-2008, 10:53 PM   #6
my67chevytruck
Under Construction
yes 71/72 were disk brakes, just did a 72 xmember swap a couple weekends back. the only thing i would be concerned with would be the inner diameter to make sure they both use the same size bearings... good luck.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 12-10-2008, 01:03 AM   #7
caminokid
Chevy nut
caminokid's Avatar
Used the whole front crossmember on mine...its out a a 87. I used the power steering out of that truck too.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-10-2008, 07:25 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
All of the 6 lug disc conversions I've ever messed with used interchangable rotors with 5 lug. Same bearings, same seals, same calipers and pads.
My 72 short bed actually has 68 model disc brake spindles from ECE. I sold the 6 lug rotors on this board and replaced them with parts store 5 lug rotors off a 73 model.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-10-2008, 09:02 AM   #9
my67chevytruck
Under Construction
thanks TX for clarifying this . I was pretty sure they would but errored on the side of caution.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 12-10-2008, 10:10 AM   #10
70 Suburban
Rods
I would be intrested in your six lug stuff. I have a comolaet 5 lug 72 front end
70 Suburban is offline   Reply With Quote
Old 12-10-2008, 06:55 PM   #11
theyammieguy
accepting donations
What all was involved with the swap? I have a 87 crossmember and rear diff coming to me from Austin.
David Crockett
Old 12-10-2008, 06:59 PM   #12
theyammieguy
accepting donations
Thanks for the info TX.
Where is Springtown?
David Crockett
Old 12-10-2008, 07:08 PM   #13
theyammieguy
accepting donations
Ok, what is a comolaet front end?
Tell you what, I have a 87 front end coming from Austin. You come down to Houston and help me do the swap and you have everything you want off my old crossmember.
David Crockett
Old 12-10-2008, 07:30 PM   #14
my67chevytruck
Under Construction
I think he meant to type Complete 5 lug front end
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 12-10-2008, 08:56 PM   #15
Tx Firefighter
30 miles west of Ft Worth
Old 12-10-2008, 09:06 PM   #16
hotrod 80
mini truck racer
hotrod 80's Avatar
I was thinging Spring , Texas was Spring town .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-10-2008, 09:13 PM   #17
69Rob
69Rob's Avatar
where you at in houston he passes that offer up maybe me and you can work some thig out i just got the front end off of a 81 still have put it in yet 5 lug has every thing needed to do the swap let me know
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 12-10-2008, 09:49 PM   #18
theyammieguy
accepting donations
Im on the south side near almeda mall.
So you want the 6 lug to?
David Crockett
Old 12-10-2008, 09:52 PM   #19
69Rob
69Rob's Avatar
ya this way i can keep 6 lug all the way around so i wont have to go and buy a 5 lug rear i paid 250$ for every thing when you say you got a the x member coming you mean the entire brake system?
73 2 door nova
54 bel air
Old 12-10-2008, 09:58 PM   #20
theyammieguy
accepting donations
I have everything coming from rotor to rotor.
David Crockett
Old 12-10-2008, 10:02 PM   #21
69Rob
69Rob's Avatar
so how much you want for the rotors? ill be putting mine on and my bags this weeken and should be getting my drop spindels soon too
73 2 door nova
54 bel air
Old 12-10-2008, 11:17 PM   #22
70 Suburban
Rods
ill take you up on it. when do you want to do it. Ill make the drive. I live in bryan now but thats no big deal. also I have all the tools that we would need to do this too. do you have air?
Old 12-16-2008, 09:18 PM   #23
theyammieguy
accepting donations
Pretty sure I have all the tools as well. I have air but my compressor trips my breaker when it hits around 80psi.
Only thing I don't have is an engine hoist.
David Crockett
Old 12-17-2008, 12:21 AM   #24
70 Suburban
Rods
just so happens i do.. I also have a glass bead blaster and a sand blaster if you want to clean them up/// also I paint.maybe powder coat?ok ok so i had a shop in houston before i moved here. Rods Rods....
Old 12-17-2008, 02:11 AM   #25
67ChevyRedneck
67ChevyRedneck's Avatar
I'm the one who bought your 6 lug rotors, they've been working very well for the past couple years. My truck had a complete stock 71 5 lug suspension under it, but because I couldn't find a 5 lug rear for a reasonable price, and I wanted to run rallys anyway, I bought the rotors instead. It was a straight swap. Bearings, calipers, etc all fit the same.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
