mini truck racer
Re: Anyone with Lexan?
For my back window I used the original rear window to cut the initail shape of the new window . I then used a compass set at 1/2 " and scribed a mark around the cut out window shape . My Lexan came with plastic on both sides of the window to protect against scratches . The scribe mark cut this plastic and i pulled it off . Buffed it with a scotch brite pad and painted it black to clean up the look . I put it in place and drilled all the holes . Ran a bead of winshield latex around the frame and pop rivited it in the indention . Then i pulled the plastic protectant after everything cured . It came out pretty good i think .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Dr. Frankenstein
THANK YOU ALL FOR YOUR HELP!!!!!
I Wanna Go Fast!! |
