12-09-2008, 02:13 AM | #1 |
Anyone used ECE 3/4 to 1/2 ton drop spindles?
hey folks, I'm in the process of my winter project and along the way I decided to ditch the hacked up coil springs and pony up for a set of drop spindles and a new set of springs.
Have any of you used the ECE 3/4 - 1/2 drop spindles and gone to 1/2 ton brakes? If so, did you have any complications with them? and problems or complaints? I trust ECE more than most companies... but a little research never hurt anything! Thanks a bunch! Kurt
384 Stroker Small Block- Best ET: 13.24@103 |
12-09-2008, 07:33 AM | #2 |
67-72 parts collector,…
Re: Anyone used ECE 3/4 to 1/2 ton drop spindles?
I'm interested in this also. I planned to convert my crew cab front suspension this way.
I think you will have to change to 1/2 ton calipers and rotors. Not sure if the rubber brake lines are the same or not. Subscribing to this one.
12-09-2008, 12:17 PM | #3 |
Never Ending Projects
Don't quote me and you'll want to verify with ECE but I think the only difference with the 3/4 to 1/2 ton spindles over the standard 1/2 ton ones is the ball joint and tie rod connections. I think the spindle is the same 1/2 ton one (and uses all the 1/2 ton brake parts) but they have been reamed to allow you to use the 3/4 ton ball joints and tie rods, which are bigger.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-09-2008, 03:21 PM | #4 |
Tot Roddin'
I agree with Chevy Mike, I would check with ECE as they will be able to give you a 100% yes or no.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-10-2008, 01:20 PM | #5 |
It'd be alot cooler if you did
Interesting, I have no use for them but will tuck this information into the back of my mind.
12-10-2008, 07:04 PM | #6 |
They work great! All you do is take your spindle out of the truck and replace with the conversion spindle...They work with the 3/4 ton ball joints and allow you to go to a 5 on 5 bolt pattern and use the 1/2 ton stuff. You just need new backing plates and rotor assemblies. I would also recommend you rebuild the existing front suspension as well. You might as well as long as you are going this route. Anyway, no machining necessary...
Burn-E |
12-12-2008, 03:14 AM | #7 |
Thanks for all of the replies! Last Chance, thanks for the info! I'll be placing my order with ECE soon!
