Old 12-12-2008, 07:50 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
400 sb
Just stumbled across a 400 small block 4 bolt main. Just a block. Guy wants $100 for it. Is it worth getting? I prefer the big blocks myself, but i know these aren't very common either. Any advice or opinions? Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-12-2008, 07:56 PM   #2
PHAT TONY
PHAT TONY's Avatar
Re: 400 sb
ABSOLUTLY!! 4-bolt blocks were only made for a couple years.
PHAT TONY is offline   Reply With Quote
Old 12-12-2008, 07:56 PM   #3
bryanschevyparts
Re: 400 sb
Eric, yes i would ,its worth 100 all day .they are getting harder to find imho
bryanschevyparts is offline   Reply With Quote
Old 12-12-2008, 08:21 PM   #4
Gray Ghost
Gray Ghost's Avatar
Re: 400 sb
Check it out VERY carefully....lots of cracked block 400's out there. I had a buddy who bought one once....not good.
If the block is good it's a bloody steal! 400's are excellent small blocks!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-12-2008, 09:41 PM   #5
shortbed70
shortbed70's Avatar
Re: 400 sb
You need to have it checked for cracks around the mains because the 4 bolt cap bolts are in a very thin area of the block and are known to crack but if not the price is great.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-12-2008, 10:16 PM   #6
big_al_71
big_al_71's Avatar
Re: 400 sb
great choice!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-13-2008, 12:17 AM   #7
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 400 sb
Two bolt blocks are stronger than the 4 bolt blocks when it comes to a small block 400. Have it checked for cracks very carefully before dumping any money into it.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 12-13-2008, 12:18 AM   #8
too much stuff
Roadtrip!
Re: 400 sb
Thanks for the opinions. I guess i will have to check it out better when i get a chance. He has a few other engines there too. I will update this when i can...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 12-13-2008, 10:28 AM   #9
bigsnookmaster
bigsnookmaster's Avatar
Re: 400 sb
Also check the bore, you don't want it if it's already .030 and needs to bore again.
bigsnookmaster is offline   Reply With Quote
Old 12-13-2008, 11:39 AM   #10
Ram-Man
Ram-Man's Avatar
Re: 400 sb
I would look it over really close also. The lifter valley cracks on them as well. Otherwise you have a $100 boat anchor. The "4 Bolt" term is highly over rated IMO.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
