Old 12-14-2008, 06:22 PM   #1
bobthecop
bobthecop's Avatar
6 to 5 lug swap
I have a '69 chasis that I am swapping the 6 lug with a '72 disc brake 5 lug set up. Is it necessary to swap the cross member, or will the '72 control arns fit the '69 crossmember??
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 12-14-2008, 06:27 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 6 to 5 lug swap
I think they will git, dont quote me on that though.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-14-2008, 06:35 PM   #3
mikeoj
Re: 6 to 5 lug swap
Yes,swap the spindles and steering linkage along with it!
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 12-14-2008, 07:01 PM   #4
bobthecop
bobthecop's Avatar
Re: 6 to 5 lug swap
thanks I'll do that, saves me a lot of work
1972 C-10
Old 12-14-2008, 07:03 PM   #5
dave2953
Dave's not here, man
dave2953's Avatar
Re: 6 to 5 lug swap
I'm quite certain you can swap the arms to the existing crossmember. Then just swap the draglink, tie-rods, etc. and you'll be good to go.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-15-2008, 01:21 AM   #6
yellowGT
yellowGT's Avatar
Re: 6 to 5 lug swap
if you dont have a motor in the truck just change the whole thing.... it should bolt right in.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 12-15-2008, 08:54 AM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: 6 to 5 lug swap
if no motor, i would swap the whole cross member, not much more work. if you dont , you will have to drill the xmember to run and bolt the brake lines down as they run different.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-15-2008, 11:45 AM   #8
bobthecop
bobthecop's Avatar
Re: 6 to 5 lug swap
WellI guess I just swap the whole thing, both chassis are engineless. Thanks for the help.
1972 C-10
Old 12-15-2008, 12:21 PM   #9
my67chevytruck
Under Construction
Re: 6 to 5 lug swap
Bob, heres a little reading for you...
http://67-72chevytrucks.com/vboard/s...d.php?t=317028
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
