Old 12-15-2008, 09:50 AM   #1
64_twins
replacement panels
Hey guys. I need to replace my rocker panels and outer cab floor on my 64. I usually try and go to LMC for most parts but they are pretty pricey compared to some other sites. Especially on the outer floor panel. About $45 more. Is this a case of you get what you pay for or am I overpaying?
64_twins is offline   Reply With Quote
Old 12-15-2008, 10:49 AM   #2
joe231
joe231's Avatar
Re: replacement panels
I believe classicparts.com carries the same stuff and it is less expensive.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-15-2008, 10:56 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
X2...that's where I just purchased my rocker replacement panels. I have to do the same thing on the driver's side soon.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-15-2008, 04:22 PM   #4
502tripower
502tripower's Avatar
Personaly I like to use the OEM rockers but I don't think they are available any longer from GM. Could be wrong though.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
