12-16-2008, 10:48 PM | #1 |
Luv the Crewcabs
Changing Coils, Why are they Loose?
Putting 3" Drop Springs in the frt of my 86, Is it Normal that they are a Loose fit while jacked up? Seems to be ok when weight is on them, Just don't seem Right that they fit so Loose................
Thanks, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
12-16-2008, 10:50 PM | #2 | |
It followed me home?
Re: Changing Coils, Why are they Loose?
thats normal, just make sure they go back in straight when you lower the jack.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 12-16-2008 at 10:50 PM. |
12-16-2008, 10:56 PM | #3 |
67-72 parts collector,…
Yep,... they are loose, because they are so short. If you have an alignment done,... make sure the springs stay in the upper seat area or your alignment will be off.
12-16-2008, 10:58 PM | #4 |
Luv the Crewcabs
Thanks Guy's,
I was more than a Little Concerned by this............ Rick
12-17-2008, 12:31 AM | #5 |
Slugish
always jack it under the control arms right under the springs > otherwise they could get out of there sockets , I have 3 in springs as well
