Old 12-12-2008, 10:59 AM   #1
50MOTORHEAD
50MOTORHEAD's Avatar
How low can you go with solid 57 axle?
I was wondering if anyone has gotten a lot of drop out of a solid front axle?
How did you go about it? Is it possible to get an axle with a lower drop than stock and if so,from who?
I know that it is possible to get a solid axles for old hot rods in just about any drop height that you want.
I want something uncluttered,simple and light,so I want to stay away from a modern a-arm set up. Thanks-Keith
50MOTORHEAD is offline   Reply With Quote
Old 12-12-2008, 12:15 PM   #2
55Series2
Re: How low can you go with solid 57 axle?
You can flip the axle (placing it on top of the springs) and you can get up to 3-inch dropped axles. Dropped axles can be flipped as well. You can also get dropped springs.
In other words you can get pretty low with a solid axle and parallel leaf springs. I can't point you at any suppliers because after researching this 7 or 8 years ago I decided to go with Fatman's MII instead.
John
Albuquerque, NM
'55 2nd Series 3100
'57 Ford RanchWagon
07 H-D Electraglide UltraClassic
55Series2 is offline   Reply With Quote
Old 12-12-2008, 12:49 PM   #3
robin58
http://www.roadsters.com/axles/
or there's someone on the HAMB I think who does it also.
robin58 is offline   Reply With Quote
Old 12-14-2008, 03:37 PM   #4
vwjohnny
vwjohnny's Avatar
www.classicperform.com
vwjohnny is offline   Reply With Quote
Old 12-17-2008, 05:03 PM   #5
bensimmons_05
bensimmons_05's Avatar
Ebay user named stay-tooned he has 3" and 4" dropped original axles. www.droppedaxles.com You can view my thread and see the axle there. Hope this helped
with a 4" drop you get serious. If you have a blowout your scraping axle. I got the 3" drop axle and removed a couple leaf springs.
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
