Old 12-16-2008, 07:01 PM   #1
superchevy
Got big-block?
superchevy's Avatar
Need opinions...14 bolt or Dana 70 for my '72 K25 dually conversion?
After reading as many posts as I could, it looks like I'm down to a choice of a Dana 70 dually rear out of an '81 1-ton Chevy for sale locally, or finding a 14 bolt dually rear. Any opinions? I have a couple of questions on widths...my stock Dana 60 rear measures 65" WMS and 53.5" backing plate to backing plate...the Dana 70 is 59" bp to bp (don't have a wms number on it yet).
You guys that have done the dually/stepside fender conversion...what width rear end did you use? I read somewhere where the 14 bolt drw was a bolt in swap...is this true?
Thanks for the help.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 12-16-2008, 07:19 PM   #2
DieselEater
DieselEater's Avatar
Re: Need opinions...14 bolt or Dana 70 for my '72 K25 dually conversion?
Either differential in dually form will have the narrow spring perches. As for strength, the 14-bolt has a far superior pinion design. The 70 has a weak pinion......Neither should give you any problems though. 14-bolts are cheaper and more common too...
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 12-16-2008, 10:47 PM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
I have a Dana 70HD Dually rear-end. The spring perches are at stock width. I will measure is tomorrow if you want it. I can measure anything you need from the axle. As far as the weak pinion I disagree! For anyone that has seen a dana 70 pinion, they would know that it is much stronger and bigger that a dana 60 or 14 bolt (sorry diesel eater, not bashing you).
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 12-16-2008, 11:00 PM   #4
JeremyPenner
JeremyPenner's Avatar
I'm a 14 bolt fan thats what we run in most our rigs, they are cheap and easy to get replacement parts for... the only thing i can think of is ratio options.. u can go lower with a dana.
'67 suburban/tahoe project
'67 swb chevy patina shop truck
'68 swb chevy roller
'48 c.o.e. chevy
'41 c.o.e. chevy
pictures of my projects on myspace...
http://www.myspace.com/localoffroad
JeremyPenner is offline   Reply With Quote
Old 12-17-2008, 07:33 AM   #5
Blazer1970
Blazer1970's Avatar
Before 2001, 14 bolts were used in cab and chassis 4X4s, and D70s were used in the duallies with the wide fenders. The cab and chassis duallies had a narrow rear end where the outside of the outer rear tires were about the same width as a normal single rear wheel rear end. The D70s are wide so that the inner tires will sit in the normal inner fenders with a bed on the truck. Two totally different width rear ends. Which width do you want?
Blazer1970 is offline   Reply With Quote
Old 12-17-2008, 12:55 PM   #6
fun in dirt
fun in dirt's Avatar
This is exactly what I was thinking.
14 bolt = cab & chassis
D70 = dually (with hips)
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 12-17-2008, 02:15 PM   #7
FormerMember
14B has a third pinion shaft bearing, where the Dana design does not. This prevents the pinion from deflecting, causing the pinion to skip (and break) teeth under load (common on 70's). Sorry, the biggest 70 pinion is not much bigger than the 14B. The shaft size is pretty close but those rarely break regardless. They also have several sizes of Dana 70's (some use 60 parts), but I am talking biggest 70 to Corp 14B.
This is why the 14B has a stronger pinion.
I am happy to provide pictures if you like, once we get our net connection and power back. Not about to post pictures on dial up and a generator.
FormerMember is offline   Reply With Quote
Old 12-17-2008, 07:31 PM   #8
DieselEater
Not offended here......Everyone is entitled to their opinion.
I'm basing my opinion on the truck pulling we do.....When you have a 700 HP solid roller Big Block hooked to a 60,000 pound sled and floor it!!!
General consensus in the pulling ranks state my remarks to be true.
Here's a link to some of my vids with a stock 14-bolt....
http://www.youtube.com/TeamFRANKENSTEIN
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 12-17-2008, 07:36 PM   #9
FormerMember
You can also add Single Rear Wheel hubs to a Dual Rear Wheel housing and get WIDE... or the reverse.
Basically, you can swap hubs onto a housing to get three separate wheel mounting surface (WMS) to WMS on a 14B.
I've broken pinion teeth on a stock 70U, never on a 14B.
Old 12-17-2008, 08:36 PM   #10
Dooley
Dooley's Avatar
In dual wheel applications I prefer the Dana rearend and in single wheel setup the GM 14 FF.
Dooley is offline   Reply With Quote
Old 12-21-2008, 02:42 AM   #11
pulltilbroke
pulltilbroke's Avatar
Go with the 14b
Dana 70s are weak and like to break the pinion
I'm a truck puller don't ask how I know
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
