Prostreet 72
Rear Control Arm Bushings
I have a question for the masses;
Are the rear control arm bushings pressed in? Do you have to have a press to replace/change them? Sorry for the question, but I replaced most of this stuff on the first truck with ladderbars..... Prostreet 72 |
Under Construction
Re: Rear Control Arm Bushings
I used sockets and c-clamp to replace ours. I have heard of people drilling the old ones out.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Active Member
I took mine to the local spring shop and had them press them in and out
You need to be careful - you can bend the trailing arm if it is not correctly supported when you press them out
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Moderator
![]() Join Date: May 2007
you could use a torch to burn them out. that has worked for me in the past.
i've used the torch removal and cclamp install on the ones i've done
Prostreet 72
If you are going to use the Urethane bushings, you need to use the existing shell, but not the sleeve and rubber, right?
Chevy nut
Same for me...this is the easiest way to get them out. Done that in the shop for years.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
