Old 12-18-2008, 06:40 PM   #1
leddzepp
Moderator
leddzepp's Avatar
Pinion angle when lowering the rear
I am going to lower the rear of my truck with 4" coil springs. I have 2" lowering blocks now, which I am going to remove, so I will have 4" lowered total with the springs. Will I need to correct my pinion angle with degree wedges? I used to lift Jeep CJ's a long time ago, and had to use wedges to correct the pinion angle. Thanks for your help.
Old 12-18-2008, 06:48 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Pinion angle when lowering the rear
I asked ECE this question when i ordered our drop kit from them (4" rear drop springs) and they stated we would not need to make any adjustments. I would like to know as well. we may go with a 1" or 2" blocks later down the road
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-18-2008, 07:24 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Thanks for your input. I may end up putting the blocks back in if it is not lowered enough for me. I wonder if lowering it in the front compensates for having to shim the rear pinion?
Old 12-18-2008, 07:54 PM   #4
Mixup
I have 4" springs and 1" blocks and the angle is ok.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 12-18-2008, 09:03 PM   #5
LuckyHenriksen
LuckyHenriksen's Avatar
I have 4 inch springs and am in the process of building 2 inch blocks, I hope it doesn't need adjustment.
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-18-2008, 09:25 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Does it do OK with the 4" springs? I assume you do not have degree shims?
Old 12-18-2008, 09:27 PM   #7
LuckyHenriksen
ya it does fine. I dont have any shims, the rest is stock
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-18-2008, 09:30 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Cool...how much are you lowered in the front? I am thinking if I lower it proportionately, it will help keep the pinion angle consistent.
Old 12-18-2008, 09:54 PM   #9
LuckyHenriksen
I have 2.5 spindles and 1 inch springs. I am thinking of hacking half a coil out to go with the blocks, making it a 4/6
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-18-2008, 10:02 PM   #10
leddzepp
Moderator
leddzepp's Avatar
I have 2.5 spindles in the front, and am wanting to go with 1" springs to lower it just a little more. I was very pleased with the spindles when I put them in last year. I currently have 2" blocks in the rear with stock springs.
Old 12-18-2008, 10:06 PM   #11
LuckyHenriksen
I would sell you my front springs (they are brand new) but I cant afford to buy another set, so I have to do with cutting them
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-18-2008, 10:10 PM   #12
leddzepp
Moderator
leddzepp's Avatar
No problem Lucky...I will keep lookin! How is your ride with the 1" drop springs in the front? Do you bottom out at all? I love the spindles because it did not affect my ride quality at all. How about alignment? Did the shop have any trouble aligning it with the lowering springs?
Old 12-18-2008, 10:18 PM   #13
larry may
Not sure may be this would help a little bit
http://www.carcraft.com/howto/91758/index.html
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 12-18-2008, 10:19 PM   #14
LuckyHenriksen
It rides really nice, surprisingly smooth for an old truck. I havent had any problem bottoming out, scraped a header collector on a speed bump at school though.... that was my own fault for driving too fast. I had no problem getting it aligned, the guys at Les Schwab was very helpful and didn't have any trouble getting it on the rack or anything.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-18-2008, 10:20 PM   #15
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
leddzepp, I have 6 inch rear coils (no c-notch...yet) and my pinion angle is fine. I too, called ECE about this and here's what they told me.
1"-2" use the stock track bar
3"-4" use an adjustable panhard bar
5"-6" us the super track bar
This will keep your pinion angle geometrically correct
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-18-2008, 10:21 PM   #16
LuckyHenriksen
great link larry
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-18-2008, 10:23 PM   #17
LuckyHenriksen
I have 4 inch springs and will be adding 2 inch blocks, does this count as a 6 inch drop? I don't want to have to buy a super track bar.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-18-2008, 10:31 PM   #18
leddzepp
Moderator
leddzepp's Avatar
Thanks for your input Harry. I do not understand how the track bar affects pinion angle though? I know it is there to keep the rear end from going side-to-side...
Old 12-18-2008, 10:37 PM   #19
SCOTI
SCOTI's Avatar
The track bar (Panhard bar) doesn't impact the pinion angle.
ECE states minimal pinion change w/up to 6" spring drops. Any more than that, you'll want to combine springs & blocks for sure.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-19-2008, 12:37 AM   #20
chevychase
chevychase's Avatar
Not to hijack, but how about the pinion angle with bags and just a c-notch?
chevychase is offline   Reply With Quote
Old 10-02-2009, 10:42 AM   #21
dznucks
dznucks's Avatar
Bump.
dznucks is offline   Reply With Quote
Old 10-02-2009, 02:02 PM   #22
71tahoe
71tahoe's Avatar
It's my understanding that pinion angle is in relation to the crankshaft/transmission shaft centerline. When you use parallel blocks the angle of the rear diff doesn't change. Shorter springs cause the trailing arms to rotate changing the angle. What's too much, I don't know.
Bags should be evaluated at desired ride height. If it's 6" then according to ECE you're OK. If you want 8" then add 2" blocks.
71tahoe is offline   Reply With Quote
Old 10-02-2009, 07:49 PM   #23
Alex Hayley
I did not read every response. I spoke with ECE before putting a 4" drop in and was told that the pinion angle will be better with the 4" drop.
Alex Hayley is offline   Reply With Quote
Old 10-03-2009, 10:10 AM   #24
leddzepp
Moderator
leddzepp's Avatar
Did you look at the date I posted this question?
Good info here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-03-2009, 10:20 AM   #25
Alex Hayley
Good info here.
Apparently I did not read that either.
