Brake logic
Hello
I have a 1972 K10 with disc up front. It has been awhile since I have owned an older truck. The brakes were terrible. Replaced the booster with much improvement. The peddle is a little harder than I would expect. If I get on the brakes hard the rear locks up. Am I looking at a problem in the front as in too little braking or am I looking at a problem in the rear with too much braking thanks |
Mean Buzzin' Half Dozen
Re: Brake logic
Your rears will generally always lock up before your front will. Just due to the fact of there being less weight in the rear. I don't think your dealing with a problem just a standard issue that everyone has with our trucks. One question I would have though, is it pulling to either side when you brake?
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan Last edited by *Dylan; 12-24-2008 at 06:23 PM. |
Re: Brake logic
sounds like it could be a bad master cylinder to me. that would be my next thing to swap, or inspect.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
Re: Brake logic
no pulling, stiff pedal I was thinking to replace the master cylinder
its all about the +6 inches
Re: Brake logic
sounds to me like they are working right.
Since there is no way to tell through words on a screen, I would recomend taking it to a brake place, or a person who would know. |
Re: Brake logic
learn the technique of braking that was used prior toABS brakes//for hard braking it isnt effective to just slam on the brakes its alot more effective to use a pulsing type of motion to avoid locking the brakes up// having a heavy load in the bed will also reduce the brakes tendencies to lockup
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 12-24-2008 at 08:49 PM. |
Re: Brake logic
you possibly have a problem with the metering or purportioning valve .it distributes presure from front to rear more in rear less in front .also ck brake adj in rear check vacum at boster and check valve on boster . a big cam wont give good vac at idle . new on sight just giving info
Junior Member
Re: Brake logic
If I remember right disc brakes are not supposed to lock up the way they are designed.
As stated before it would be a good idea to replace the master cylinder just because of the age of these old trucks and check the proportioning valve Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: Brake logic
You have sold me. A new master cylinder it is
thanks |
