Old 04-02-2002, 02:09 PM   #1
bigd65
bigd65's Avatar
Post tell me what yall think
well let me start from the beginning,
i had my carb (1406) adjusted great, a little rich at idle but ran great. at one time, when i first installed the cam (XE262 k kit) i had a very little bit of spark knock at mid-throttle, so i went to a heavier step up spring for the metering rods (from no.4 to no.5) that cured the problem, ran great. now i am pretty sure about what i am going to do but i would like a second opinion.
my problem now sence i put the MSD module and the MSD super conductor wires,is now i have spark knock at wide open throttle, BTW i have the HYPERTECH POWER COIL. i already retarded my timing from 10 degrees to 8 degrees. the vacuum advance is hooked to manifold vacuum, but at wide open throttle, the vacuum advance has no role in the timing. i also have the heaviest spring for the advance weights in the distributor. what i am planning on doing is to go another stage richer on the jets for the secondaries. stock calibration for this carb is pri-.98/sec-.95 and no.4 step up spring. as i have already said i already went to the no.5 step up spring and have already went to .98 jets in the secondaries. i am thinking i need to go to the .101 jets in the secondaries to cure the wide open throttle spark knock. i am pretty sure this is what i need to do but if anyone else has anything else to add please tell me if i am missing anything.
BTW,judging by the the pull this thing has now, if i put the bigger jets in it and it corrects my problem this thing is going to have a neck snapping second gear that wont quit. thanx in advance for any help/opinions yall can give
85 C10 LWB 350/700R4
COMPCAMS XE262 "K" kit
compcams magnum roller rockers (SOON I HOPE)
91 BURB FRONT GRILL
HOLLEY STREET DOMINATOR INTAKE
EDELBROCK 1406 PERFORMER SERIES CARB
FACTORY HEADERS (1 TON)
MAGNAFLOW CAT/MUFFLER/ 3in. EXHUAST
3.42 REAR GEARS
PROTHANE SUSPENSION-TOTAL KIT
DUAL 13"in ELECTRIC FANS
SERPENTINE CONVERTION FROM AN 88'YEAR MODEL
"THATS MY TOY"
Jeff Dodson
Angleton, Tx.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 04-06-2002, 02:19 PM   #2
bigd65
bigd65's Avatar
Post
ANYONE !!!!!!!!!!!!!!!!!!!!!!!
2017 Chevy Tahoe
