12-27-2008, 09:34 PM | #1 |
my headlights dont work
hi everybody, on my 67 gmc i was driving today i turn headlights on and work good for like 3 miles then they went dark, i kept on driving and got home ok. so i check everything i could up to now so far all the other lights are working fine im thinking is the dimer swtich does anybody know? before i buy it
12-27-2008, 10:05 PM | #2 |
Restoration Virgin!
Re: my headlights dont work
I say double check the easy stuff...grounds, plugs, light bulbs, etc...
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
12-27-2008, 10:13 PM | #3 |
Could be the dimmer switch connection that is what happened to me, the dimmer switch was brand new put the three wires were corroded that is most likely what happened.
[Dont Trasem' Restorm |
12-27-2008, 10:13 PM | #4 |
also check the dimmer switch. Mine did not work so I tried different bulbs, tried the non-working bulbs in a differnt truck and the worked. Chaged the dimmer switch and wal-la "let there be LIGHT" AHHHHHH...
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
12-27-2008, 10:16 PM | #5 |
dimmer switches r cheap//but yes check the easy(free)stuff first dont forget the fuse
