Old 04-10-2002, 03:47 PM   #1
kman381
Post axle flip
How much will an axle flip kit lower the back of the truck. I'm considering purchasing a flip kit but don't know how much it will drop it so I know what to buy for the front.
kman381 is offline   Reply With Quote
Old 04-10-2002, 04:35 PM   #2
78ondaflr
Post
Should drop you about 5 inches, but every truck is a bit different..
78ondaflr is offline   Reply With Quote
Old 04-10-2002, 11:21 PM   #3
MADRAD
Post
www.offroaddesign.com
they make a 4 inch shakle flip.. look them up or call
I'm the third owner of this 74 Chevy K-5 Blazer mostly stock back in the day. Since the start of the build up the truck now has a 540 Tall Deck Big Block Chevy, 4.5 bore, speed-o-motive 4.25 stroked crank, 10 to 1 pistons that are 60 over, 800 CFM performer carb on a 454-0 aluminum intake, Brodix 2X aluminum heads with full rocker cam and 7:1 lifters. hooker heads with 2" primary and 4" collectors to a pair of flowmasters. A preped 700R4 rated to 700HP, 205 T-case, Dana 60 front limited slip, Corp 14 bolt rear lockers, with 4:88. Working on a 4 link coil over spring front suspenion with 63inch leaf link rear suspenion. Running 38 Ground Hawg tires on custom 16.5 Trail Ready bead locked rims. Custom dash with Auto meter gauges, Bear custom seats, 8 point roll cage and lots of other goodies. Its my money pit land boat, but I love it!!
MADRAD is offline   Reply With Quote
Old 04-11-2002, 07:26 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking
You can add another 1/2 to 1 inch drop by removing the load spring too. I removed it on my truck. The standard flip kit is 5".
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
Gerardo a.k.a. Mad Chemist
Silverado XST videos
