Old 12-27-2008, 12:14 AM   #1
mobileortho
mobileortho's Avatar
Wheel Centering part II
Started working on getting the rearend centered today. I decided to drill a centering hole in the main leaf. I moved it back 2". While I was at it I went ahead and removed two leafs and added the wheel spacers. Worked into the night (sucks not having a garage) but here are the results:
passenger side
drivers side
I think it turned out pretty good. I'll take some more shots tomorrow.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 12-27-2008, 12:18 AM   #2
50adrod
50adrod's Avatar
Re: Wheel Centering part II
looks good, not having a garage makes things take twice as long, I am very lucky to have the shop space I do.
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 12-27-2008, 02:48 PM   #3
solidaxel
solidaxel's Avatar
Looks like it is just right!
What size tires are you using?
Can you take a measurment from the rear of the frame hornes to the center line of the axle housing after you moved the axle to the rear.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-29-2008, 09:53 AM   #4
Houston54
It looks like you have them in the correct location but your decision to drill the leafs went against the advice of about 90% of the people who responded to your first thread on this subject. I hope that decision does not come back to bite you.
Houston54 is offline   Reply With Quote
Old 12-29-2008, 08:11 PM   #5
mobileortho
The tires currently on the rear are 235 55 17 on 8" rims, but those will be replaced.
From the rear of the frame to the axel centerline is 34 1/2".
Robert C.
1950 3600
