Texas Big Wig
Trans questions
Hey guys, I have a few questions about parts interchangeability (< big word
![]() I have a Nv-3500 5-speed & I need to know if my old 3-OTT clutch, pressure plate, disc & stuff will work with the 5-speed (are the input shaft splines the same) Also I am missing the throwout fork & the hydraulic clutch stuff, but I have a NV-4500 with the fork & hydraulics will they work on the 3500 ??? Thanks in advance, Matt |
Texas Big Wig
Help
Help me out guys, I need some answers on this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=320950 Thanks, Matt |
Resident of Here
Re: Help
Bump
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
![]() Join Date: Jan 2008
Re: Help
may wanna ask a moderator if they can move that other thread over here for ya. cuz having multiple threads on same subject is frowned upon here. just an FYI
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
Re: Trans questions
i dont know to much about transmisions, but my family does own a junk yark and i rip apart vehicles when a customer needs something and the shop guys are to busy with other stuff to get to it, i recently pulled an nv-3500 out for a customer and i could be wrong but the spline looked different then the spline on my sm465 or my sm420
i would say the best bet with the clutch would be to test fit the clutch on the spline, and i would give a local junkyard a call and ask about the throwout question, they should be able to answer the question for you let me know if you have trouble finding the answers i can talk to one of the shop guys who probly would know, but that wouldnt be till about thursday or friday nate good luck geting the info you need
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
Re: Help
Im sorry I aint got a clue matt but heres a bump for ya bud TTT
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
Texas Big Wig
Re: Trans questions
Well I tested my clutch disc on the the input shaft & it fit just fine, so that should work
Now I just need to know if the throwout arm will work, cuz I think the hydraulic master & slave cylinders will work (just made a quick look under the truck & they look the same) Hope it all works, cuz I'm short on cash & need to get the trans bolted to the engine fairly soon so I can stick em back in |
Resident of Here
Re: Help
Bump
1970 Daily Driver
Re: Trans questions
Spray-Bomb. I put a NV3500 behind my 327 and used all of my old clutch set up. I had a newer clutch for a small block laying around that I tried first but it had clearance issues with the bellhousing. I had put it all together and gave it a turn over with the starter and a spare battery and it sounded like I was chewing up the flywheel but it just turned out to be the clutch housing rubbing on the bell housing of the transmition. I took it out and messured bolth the newer and old clutch, the old one was a smaller circumferance so I used it and have had no problems. So even if it fits on the shaft make sure it clears the bellhouseing through a full rotation. I hopes this helps some.
I can't tell you much on the throwout fork & the hydraulic clutch interchangeability.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
