Pics for CPNE
here are the pics for ya
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
Resident Curmudgeon
![]() Join Date: Dec 1999
Re: Pics for CPNE
I see in the second pic where the snap ring retaining groove is covered by the inner hub piece. But what's the 3rd pic showing as i see the groove in it?
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Re: Pics for CPNE
the third pic is without the ring i labeled in the first pic. that is what i was talking about on the phone.
Resident Curmudgeon
Re: Pics for CPNE
So basically you're showing in pic 2 that the outer axle stub does not quite protrude thru the hub far enough to expose that snap ring groove. But its pretty close right? I think its a matter of prying that axle shaft outward because of the new seal and washer behind the spindle.
Re: Pics for CPNE
Mine did that, hold the hub assy. in and reach around to the axel ujoint and push the axel out wile holding the hub in. This should alow the end of the axel to expose the groove for the snap ring.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Resident Curmudgeon
Re: Pics for CPNE
Thanks Burt. That's exactly what we did last night, kinda a 2 man job. Its all back together now
